Page 374 of 554 FirstFirst ... 274324364370371372373374375376377378384424474 ... LastLast
Results 3,731 to 3,740 of 5533
    #3731
    So walang function to unlock the doors when you remove the key from the ignition?
    #3732
    Quote Originally Posted by shok View Post
    Pwede yang 4 features sabay sabay naka-on kung CVT.
    Kung MT/ Yung #3 at #4 lang ang pwede.
    Bakit ayaw sakin? Pa activate ko kaya sa casa
    #3733
    Ano ang gusto mong iactivate?
    Yung shift position linked door lock and unlock?
    Shift position linked door lock (for G-A/T only):
    1. All doors should be closed.
    2. Switch the ignition to "ON". Keep the shifter in "P"
    3. Within 20 sec of step 2, press and hold the lock button for at least 5 sec.
    4. Release lock button. There should be a cycling of the lock unlock. This means that the programming is successful.
    Shift position linked door unlock (for G-A/T only):
    3. Within 20 sec of step 2, press and hold the unlock button for at least 5 sec.
    To cancel the function, perform the same steps.
    #3734
    Wala Jut, but you can activate #4 which unlocks all the doors when you pull the driver side inside door opener within 30 seconds of turning off the engine. If #4 isn't activated, only the driver door unlocks.
    I didn't activate this on mine na because I set it to unlock when I shift to "P" which we normally do before turning off the engine.
    Sa techstream, on off lang itong mga features na ito. Wala ng complicated steps.
    Apr 2014
    #3735
    It works, thanks. But was thinking na sana may option din na mag-unlock sya kapag engine off na. Minsan kasi pag heavy traffic I use "P" instead of N+handbrake. But anyway this will do.
    #3736
    Yes. This is what I did. I closed all doors. I stepped on brake then shift from P to N. Pressed the lock for 5 secs. Did not hear anything :cry:
    #3737
    Are you trying to disable/enable the speed sensing lock? "N" and lock for 5 seconds is for the speed sensing lock. Is the key turned to "ON" too?
    Just checking lang ha. But that's strange.
    I wasn't able to do this manually too the first few times. When I got it right, it becomes easy na.
    #3738
    Quote Originally Posted by tevilo View Post
    Try deactivating #3 and activating #4. That's the closest to unlock after engine off that we can get.
    #3739
    No. I don't want to disable the speed sensing lock.
    I want to enable the feature na shifting between P and N will lock/unlock
    #3740
    Oh, don't shift to "N" after turning the key to the the "ON" position.
    Keep the shifter in "P", then press and hold lock for 5 secs. This is for the door locking.
    Holding unlock is for the door unlock function.
Toyota Corolla 11th Generation Altis [Merged Threads]
