Page 19 of 22 FirstFirst ... 91516171819202122 LastLast
Results 181 to 190 of 218
    #181
    Quote Originally Posted by rukawa11 View Post
    Nagpa 1k PMS ako, after uwi ko ng bahay inangat ko hood nakakita ako ng cutter at pinagtabasang 2 maliit na tela sa makina.. Galing! [emoji90]
    anong tinabas sa makina, tela?
    #182
    Naiwan yun tinabas na tela sa makina
    #183
    hinati niya yung isang vasahan, at binilang na dalawa! dalawang basahan ang pinayaran nyo po, kahit na i-isa lang siya na pinutol sa gitna.
    but ok lang. may bago kang cutter. nakabawi ka na rin.
    Sep 2014
    #184
    Cutter P66 lang sa Japan Home or Daiso
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    #185
    38 pesos singil ng casa sa basahan.
    dalawa raw ginamit. that's 76 pesos.
    but since they actually used only one basahan, making it appear to be two by cutting it in half using that cutter, you should have been billed only 38 pesos, not 76 pesos.
    na-overcharge ka ng 38 pesos.
    but you got a 66 peso cutter for the 38.
    you're ahead.
    Sep 2014
    #186
    Grabeng casa, turnilyo, basahan, china-charge pa, baka sa susunod pati panlinis ng kamay ng mekaniko
    Why not just remove those fat execs sa top tier. Parang comouter shop na lang naman kotse ngaun, di naman kelangan ng sobra dami manager for one dealership
    Jul 2016
    #187
    We only go to casa when we have Check engine/tranny/airbag/EPS light na di na kaya basahin ng ebay OBD2 scanner ko. Pa diagnose ko sa scanner nila then ako na mag repair and reset ng code.
    Pag nag ka bonus sa pasko hopefully makabili na ng high grade ecu scanner para di na dependent sa casa unless mag labas ng ECU update like sa case ng all new Fortuner. Of course, even if you have a good ecu scanner that can perform ecu reflash/update, the updated version software/patch will still come from them(casa.)
    Sep 2014
    #188
    Quote Originally Posted by Janemar View Post
    Sa lazada meron. 5k, 7k and 10k worth. Ship from abroad. It says there it can reset SRS and ABS sp i figure yun na yun high-end
    What can u recommend from Lazada
    May 2012
    #189
    Bumalik ako last Saturday para magpakabit ng spoiler worth 7.5k sa casa. Check ko yung spoiler, nakita ko yung dalawang side (kanto) kulang sa paint[emoji36]
    Pati yung microfiber sa likod ng hatchback ko nawawala ginawa palang pamunas ni mekaniko after ikabit spoiler. [emoji107]
    May 2010
    #190
    Bigla ko tuloy naalala na my battery died a week after a PMS. According to the batt check ok pa naman daw yung battery. Di kaya nakahuyan ako? Tsk.
Do You Still Trust The Casa?
