Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
    Jan 2008
    #31
    Dapat all four. Dapat nga magsimula sya from the side farthest from the fluid reservoir which is, in most cases, the rear passenger side. Tinamad siguro magtanggal-kabit gulong. Or wala syang kasama to keep an eye on the fluid reservoir and keep it filled.
    Still looking for a shop that can bleed brakes in the Pasig/Taguig area. Asked Shell, Bridgestone, and Petron and they all say na wala silang pang-bleed.
    Buy ka na lang sir ng pang bleed sa lazada.. wala pang 1k yun.. magagamit mo pa.. tsaka hindi bugbog yung brake master mo sa pag bomba
    Dec 2017
    #32
    If I may ask, do you have a link? Is this the one whom a single person can do it?
    Aug 2004
    #33
    Yep nasa wishlist ko na. Still don't have the time to do it. Sikip din kasi sa garahe namin. I used to be able to cross-rotate my car's tires in less than an hour. Di ko na kaya lately :P
    I'm also waiting for my friend's DIY bleeder that will use a defunct refrigerator compressor to suck the fluid out. Kung natuloy will update.
    Jun 2005
    #34
    Just so the 1 man brake flush.
    You just need a bottle
    (Softdrink or whatever you got) clear plastic hoses and brake fluid. Madami sa youtube.
    Sobrang dali gawin.
    Sent from my MI MAX 2 using Tapatalk
    Jan 2008
    #35
    Dont know how to post link.. just search brake bleeder.. meron yung need mo ng air compressor..meron din na may manual hand pump.. yung binili ko yung may manual pump.. napaka dali gamitin at hindi messy..
    #36
    Hanap ka yun Meron vacuum, alam ko sa customer's cradle meron dati.
    Para tangal talaga lahat ng brake fluid mo.
    Dec 2017
    #37
    #38
    Pagawa mo na lang ₱350 lang labor. Hinijigop yun old fluid using vacuum then meron air compressor. Wala ka pa pagod.
    Sep 2019
    #39
    Quote Originally Posted by tensazangetsu View Post
    Thanks sir! Tawag ako sa motech bukas. Dapat pala tinanong ko na sa mechanic agad bakit hindi niya nibleed yung iba.
    Went to motech and they already bleed the remaining 3. Nagkamali daw ng intindi yung mechanic dun sa sinabi nung service advisor ata nila.
    #40
    Palusot. Common sense naman na dapat I bleed lahat.
Change ng Brake Fluid
