Page 2 of 2 FirstFirst 12
Results 11 to 20 of 45
    Jul 2011
    Mga 350 ata... It's like a suction machine operated by their air hoses.
    ah pwede na. thanks.
    Sep 2013
    Checked with Wheelers Suspension Haus. 350 pa rin ang labor sa brake dialysis while sa Speedyfix ay 600 ang labor sa bleeding for 30mins to 1 hr. Wala daw ang speedyfix na brake dialysis na ginagamit. I'm guessing na mano mano ata ang pagbleed nila.
    Bat kaya mas mahal sa speedyfix? Given these 2 prices, which service shop would you recommend? Pls help me to decide mga tsikoters. TIA
    Sep 2013
    Sir newbie here. anong purpose po ng brake dialysis? need ba ito before change ng brake fluid since wala naman akong nararamdaman unusual sa braking. Gusto ko lang sana magchange ng fluid as PMS.
    Wheelers Suspension Haus also has a "brake dialysis" machine.
    Try Goodyear Servitek also.
    Aug 2004
    Quote Originally Posted by kimbon View Post
    Brake fluid absorbs water and breaks down with age. This may cause corrosion and vague braking feel. Dialysis ensures that all your old brake fluid is sucked out and replace with a fresh batch.
    Hanap ka yun Meron vacuum, alam ko sa customer's cradle meron dati.
    Para tangal talaga lahat ng brake fluid mo.
    Dec 2017
    Pagawa mo na lang ₱350 lang labor. Hinijigop yun old fluid using vacuum then meron air compressor. Wala ka pa pagod.
    Pero in this case. Palusot na lang yun. Lahat naman siguro ng mekaniko alam na i-bleed yun lahat ng brakes and hinde lang isa.
Change ng Brake Fluid
