Page 7 of 17 FirstFirst ... 34567891011 ... LastLast
Results 61 to 70 of 162
    #61
    Quote Originally Posted by oliver1013
    orig pads ng 03 pajero ko ang kapal pa pinalinis ko pa ang ingay parin!!
    pa-check mo rotors bro. baka may sabit. kapain mo yung likod (kadalasan to meron) kapag may mga lubog na part, yun na yung cause nung ingay. sumisingit kasi yung dust particles dun kaya kapag nag-brake ka, maingay.
    #62
    Quote Originally Posted by speedyfix
    we can order for you depending on what car it is for...
    May bendix or bosch ka ba sa shop? pa Pm naman how much. Thanks
    Nov 2003
    #63
    call the shop if you need a price. the number is in my sig
    Nov 2003
    #64
    R-Spec? Try looking at an actual sample, then that should speak for itself. Comparing it with bendix and Bosch is like comparing apples and oranges. When buying brake pads, insist on buying only NON_ASBESTOS pads. Asbestos is also very bad for the environment.... Most brake pads now come with asbestos. Guys this is a silent killer and since 2003 it has been banned completely in other countiresa due to the bad effect it has on your body. Asbestos can cause cancer, and directly affects your lungs. I suggest you guys try the Bosch power plus line. Bosch also has a standard line but all pads are NON ASBESTOS if you love your rotors, and care for your safety then I recommend these.
    Aug 2016
    #65
    Whats the best value brake pads for ranger 2017? The choices are OEM, brembo, bendix and Icer
    Sent from my SM-N920S using Tsikot Forums mobile app
    Dec 2013
    #66
    Quote Originally Posted by miguel20 View Post
    Ford Ranger - For American cars like Ford try Motorcraft, for GM, Cadillac, Chevrolet & Buick try AC Delco.
    #67
    Quote Originally Posted by JapanABC View Post
    Bro how about for Japanese cars?
    Apr 2017
    #68
    Hi Dude, I just bought an '09 Sta. Fe and I just feel like the brakes are on the weak side. Do you have a recommended fix or Brand/Shop not at the level of Brembo's? Cheers!
    Jul 2016
    #69
    Bendix general ata yun. Ok naman parang oem din
    Sent from my SM-J500G using Tsikot Forums mobile app
    Quote Originally Posted by CRDI Tantor View Post
    weak brakes? it could be bad shock absorbers. if theyre bad, the front will nosedive alittle more and if the road is not perfect traction is lost.
    brake fluid changed?
    how is the handbrake? 5-7 clicks?
    or bad scenario, brake booster lost vacuum..
Brake Pads
