Results 61 to 70 of 162
June 2nd, 2006 03:49 PM #61
Originally Posted by oliver1013
pa-check mo rotors bro. baka may sabit. kapain mo yung likod (kadalasan to meron) kapag may mga lubog na part, yun na yung cause nung ingay. sumisingit kasi yung dust particles dun kaya kapag nag-brake ka, maingay.
- May 2006
- 12
June 2nd, 2006 04:25 PM #62Originally Posted by speedyfix
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Nov 2003
- 71
July 28th, 2006 08:53 AM #64R-Spec? Try looking at an actual sample, then that should speak for itself. Comparing it with bendix and Bosch is like comparing apples and oranges. When buying brake pads, insist on buying only NON_ASBESTOS pads. Asbestos is also very bad for the environment.... Most brake pads now come with asbestos. Guys this is a silent killer and since 2003 it has been banned completely in other countiresa due to the bad effect it has on your body. Asbestos can cause cancer, and directly affects your lungs. I suggest you guys try the Bosch power plus line. Bosch also has a standard line but all pads are NON ASBESTOS if you love your rotors, and care for your safety then I recommend these.
- Aug 2016
- 194
April 6th, 2017 11:53 AM #65Whats the best value brake pads for ranger 2017? The choices are OEM, brembo, bendix and Icer
Sent from my SM-N920S using Tsikot Forums mobile app
- Dec 2013
- 527
April 8th, 2017 10:39 AM #66
- Mar 2010
- 2,270
- Apr 2017
- 3
April 8th, 2017 04:07 PM #68
- Jul 2016
- 1,178
April 8th, 2017 04:27 PM #69Bendix general ata yun. Ok naman parang oem din
Sent from my SM-J500G using Tsikot Forums mobile app
April 9th, 2017 01:36 PM #70
weak brakes? it could be bad shock absorbers. if theyre bad, the front will nosedive alittle more and if the road is not perfect traction is lost.
brake fluid changed?
how is the handbrake? 5-7 clicks?
or bad scenario, brake booster lost vacuum..
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; April 9th, 2017 at 01:57 PM.
