Page 40 of 44 FirstFirst ... 30363738394041424344 LastLast
Results 391 to 400 of 436
    #391
    Totoong ceramic ba ang brembo pads? Hinde niya kainin ang stock rotors like yun metal king ng bendix?
    Ano ba advantage ng ceramic, meron ba kahit stock lang rotor?
    Jun 2013
    #392
    Ceramic daw. Yun nakalagay sa box. I can't tell the difference when I installed these.
    I think I'll go back to OEM or maybe I'll try Akebono.
    Nagiging maingay kasi after long drive or after byahe sa mountain roads.
    #393
    Diba dapat less dusk and less movie pag ceramic?
    #394
    supposedly ang advantage daw ng ceramic less dust at less noise
    Feb 2009
    #395
    brake noise attributed to the recent replacement of disc pads are usually caused by glazing of the brake rotor surfaces. some oem brake pads like those of honda have a light coat of abrasive on the surface of the pad to aid in the deglazing of the brake rotor. new brake pads have to be burnished in to seat them to mate with the old brake rotor. other causes of brake squeal are stuck caliper slide pins (floating calipers) or sticking caliper slides (sliding calipers). simply installing disc pads without relubricating slides and prepping the reused brake rotors will usually result in singing front brakes
    #396
    so ganun pala ka important lihahin ang rotors and new pads pag pinalitan. i can remember on one occasion wala ako liha deretso palit lang ng pads.
    Jun 2013
    #397
    In my case I installed the brembo brake pads with brand new rotors, hell I even replaced the rubber protecting the caliper pin and greased the pin using OEM stuff. It is noisy after long drives only.
    Apr 2005
    #398
    My brakes are noisy in the morning. Squeel. The pads original from Toyota casa are fairly new, maybe 20Tkms old. What could be wrong? TIA
    Sep 2021
    #399
    Try to remember if umulan ba ng malakas or if you washed the car/tire na nabasa yung rotors.
    Baka from flash rust lang yun.
    If that's the case, nalilinis as you use them kaya nawawala later on in the day...
    Feb 2009
    #400
    were the new brake rotors cleaned off of the rust inhibitor prior to installing? this post is months old. is the car's brakes still behaving this way?
Brake Pad Thread [Merged]
