Results 31 to 37 of 37
- May 2008
- 5
May 31st, 2010 10:51 AM #31i've read na ang mga parts can be purchased sa servitek. can someone direct me to a distributor ng stavic parts? i need a brake (light) switch. ayaw gumana ang AT ko. dapat de-pindot pa yun switch sa ilalim ng M<>D para maikambiyo
ang haba ng pila sa wheels service ngayon
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 8th, 2010 12:39 AM #32AFAIK, servitek only has Stavic parts normally used for oil change like filters, etc. Their fan belt works but it wont last.
There's a store in Banawe called Hybrid that sells some Stavic parts for a lower parts pero chambahan regarding parts availability.
Bottomline, if you need to read the ECU, you're stuck with E. Rod. If you don't need it, you can opt for Hyundai Manila Bay (same owners) or even CATS (same owners, same engine). If you want to save a bit, get the needed part numbers first and ask Hybrid if they have it ...
- Jun 2010
- 466
- May 2008
- 5
- Sep 2008
- 1,219
August 8th, 2013 10:07 AM #35guys i'm planning to buy this car meron ako nakita sa sulit 08 model, take note po, ibebenta ko ang vios ko na 09 model for this
and this will be my only ride if ever (stavic) kase need ko ang malaking sasakyan malalaki na mga bata di na sila kasya sa sedan.
madali lang po ba hanapin ang parts at hindi po ba mahal ang pa PMS? can the PMS be done sa mga petron car care centers? thanks po
innova is way out of the budget and second option ko is grandis kaso sa 05 model lang aabot money ko...any good advice?
- Dec 2009
- 5
October 13th, 2015 09:55 AM #36It's been a while. . . well papalinis na ata ako microfilter. . . san kaya pwede palinis mga sir? layo kasi ng e. rod
- Sep 2018
- 4
September 22nd, 2018 09:11 AM #37Saan kaya makakabili ng pyesa piston ring nito?
Sent from my SM-G531H using Tapatalk
Tesla Philippines
