Results 121 to 130 of 2730
- Apr 2004
- 20
June 23rd, 2005 09:23 PM #121bro dun mo nlang dalin sa rdd engineering kay mang rene. sa bulacan yun malayo pero worthy puntahan kc mura sya maningil e!labor nya is 7k lang for overhaul madami nko nakita nagpa overhaul ng mb100 dun.eto number nya0446680628.just tell him recommended ka ni romel
- Feb 2005
- 99
June 24th, 2005 01:52 PM #122rvm519 ..
thanks rommel for the info. i was looking even before for a mechanic close to my place. i live in marilao and i prefer nga sana close to my area para mabantayan ko.
i brought my unit this morning to mcr and ther already started working on my van. they are now in the process of taking down the engine. i will visit them again this afternoon to see them work.
i will call rdd engineering so at least whenever i need a mechanic, they're the closest to my place.
thanks again!
- Apr 2004
- 20
June 27th, 2005 10:37 PM #123ok bro!thats predestined to happen.anyway,hope everything will go smooth. just call mang rene if you need a closer shop.He is very dependable coz all his life he is a chief mechanic in germany,u.s,middle east.Hes standard is high simply bcoz hes an aircraft chief of boeing.also knows very well on automatic tranny,every time i go there he is working on one.overhauling engine and tranny is an ordinary thing in there.
June 28th, 2005 04:10 AM #124
Originally Posted by rvm519
dude, saan located si mang rene? im from malolos...but had our mb100 serviced sa cats..
may engine knock ung mb100 namin, and i was told baka i need to replace the nozzles...baka ok din gumawa dun and then malapit pa..
- Apr 2004
- 20
June 28th, 2005 10:38 PM #125He is located at cupang bulacan.much better bro if you call mang rene 0446680628 tell him you were recommended by romel thru the internet.
- Feb 2005
- 99
June 29th, 2005 10:58 AM #126Spidey ...
have your nozzles cleaned baka fuel knock lang yan.
BTW, yesterday okay na yung van ko. Nabuo na ang running na yung engine although they still have to make some testing and adjustments. I will also have my nozzles cleaned kasi nagkaroon din ng fuel knock. Break-in nila since yesterday hanggang today and makukuha ko na yung van mamayang hapon.
Okay naman yung gawa ng MCR. I'm happy with all the help that they extended me. Medyo nag overshoot lang ng konti sa budget (P46K total) pero okay lang. Nandiyan na yan e.
Thanks for all the advices!
July 1st, 2005 09:38 AM #127
Re: the intake, Commercial Motors issued a recall on early local MB100's for an improved intake system.
Ours was included in the recall.Will post pics.
- Feb 2005
- 99
July 1st, 2005 11:15 AM #128Sir OTEP,
I also changed my air intake. before I have the original Ssangyong air intake duct pointing down. This is one probable cause of my problem. The original intake is way down below the hood. It's opening is also exposed from outside the hood so it is really possible that it will take some water in and into my engine.
I bought mine from Apic. They sell a set of it for P1K. The set includes the intake duct, a small cover for the inlet just above the radiator and weather strip for the hood. A small amount to pay to protect my newly overhauled engine.
When I got my unit at MCR, there was a knocking sound from my engine. I suspected my nozzle tips. According to their mechanic, it was normal but I doubt it. I also suspected the timing of the injector but the mechanic said that he already set the timing the best he can and insists that the noise will eventually subside after I use my van for a while. I made a visit to my other mechanic and just by listening to the noise and without checking anything he said it is definitely the timing from the injection pump. He also warned me that it might damage my crankshaft if not fixed immediately.
I had no ther choice but to ask this mechanic to fix the timing since my MCR mechanic already said that that's the best he can do. After the fix, my engine is a lot smoother and quieter. Hmmm.. does that mean that MCR is not really that familiar with MB, at least with the timing thing?
Anyway, I was really concerned that's why I had it fixed right away. Too bad, it's an additional cost for me.
Wheeew! Hirap pala ng overhaul. Anyway, at least my van now is running good.
July 1st, 2005 11:27 AM #129
Hi Wax, could you please share the name and location of your mechanic the fix the timing. My officemate is looking for one for his MB100D too. Maybe I could recommend him there. Thanks.
- Feb 2005
- 99
July 1st, 2005 12:43 PM #130Field Master,
The mechanic I was referring to is the mechanic of Apic Auto Supply in Banawe. His name is Jorge and I can say he is really good. They specializes in Korean vans but mostly MB100Ds. He used to work at commercial motors.
Tesla Philippines
