Page 286 of 307 FirstFirst ... 186236276282283284285286287288289290296 ... LastLast
Results 2,851 to 2,860 of 3070
    Dec 2017
    #2851
    *JohnM - ask Mickey if he has a Focal or DLS package. I'd with any of those two brands. Maybe third option is Morel.
    So, DLS is really good... I thought I made a mistake with it.
    #2852
    Based on the feedback here my first choice will be Morel. I like it warm. Haven't auditioned any brand yet though so I'm open to other options. I won't go above 20k for seps kasi baka sayang lang ang capabilities ng speakers sa use case ko.
    imo, both options are good.
    i did option 2 sa suv ko, good quality seps saka deadening ng front doors. tonality wise big improvement siya same source as yours spotify saka dap with hi-res music. until now wala pa ako urge to add amp and a sub, ok na ako sa sound ng hu at seps.
    i did option 1 sa car at van ko. palit lahat in one sitting. ok din naman if may enough budget ka. isang gastusan na lang, hassle din kasi magpabalik-balik pa sa installer lalo kung malayo ka.
    Parang leaning towards option 2 din ako. Less invasive and baka masaya na ako sa simple speaker upgrade and deadening lang. Ayoko kasi maglagay ng amp under the front seats so if they put it in the trunk may woodworks pa kelangan to install it somewhere that won't affect the luggage space much. Will still depend kung anong speaker ang kayang i-drive with the stock HU. Will definitely listen to the installer's advice when the time comes.
    Apr 2012
    #2853
    with your budget now, option 2 ka nga bro. check out other popular brands like focal, helix, dls and others. installed focal sa car and van ko, bewith sa suv, all are entry level seps lang yet the sound improved a lot in terms of tonality. i'm not into hardcore audio set-up so hindi ako too clinical whether warm or bright, o kaya yung mga imaging, soundstage, etc. if your music source is good at maayos pag-tune ng installer sa speakers then ok lalabas at magiging mas enjoy makinig while driving. try mo muna walang amp at subwoofer, kapag nakulangan ka sa ingay at bass saka ka na lang magdagdag.
    #2854
    Yep, DLS is really good. Even their budget Reference series are quite good. My old Exalta before had DLS speakers and amplifier in a 2-way active setup.
    If you are leaning towards warm-sounding speakers, I would suggest DLS. Morel also had that warm-sounding speakers. These two brands though have speakers that need a bit more power to give them that oomph so I suggest you get a decent amp to power the speakers properly. DLS, Focal, Genesis, Audison, Helix, and JL are a few of the good brands for amplifiers. You can also use some of those newer, more compact class D amps which could easily fit under the front seats.
    #2855
    Thanks for the inputs guys. At least may direction na ang plano ko
    Will update kung natuloy. Most probably kay Micky ako papagawa as they're the most convenient. Medyo malayo na si Jonz sakin and allergic ako sa Ortigas Extension Any other recommended shops in the Taguig/Makati area?
    #2856
    Check mo with Alex Ong of Autoline Makati kung ano mga ma-offer nila. However, malaki tiwala ko kay Mickey. Doon rin ako kumukuha ng audio equipment sa kanya before. From Sucat, dinadayo ko pa shop ni Mickey.
    #2857
    I prefer yung mga shops na specialized sa car audio kaya medyo low on the list si Autoline even if they're nearer.
    IIRC Mickey did a Mazda 3 din a few years ago. At least kampante akong alam nila ang ins and outs ng oto. Integrated kasi ang HU ng Mazda iba ang setup compared to the usual DIN HUs.
    Apr 2012
    #2858
    not in taguig/makati but check out jc car audio, timsaudiogarage, c&j autosound, quest car audio, musico mobile audio to name a few
    Apr 2006
    #2859
    i started at straight jbl setup - seps + amp, then after few months added a 12” subs on a ported box with mono amp.
    then it evolved to several brands...and ended up to straight RE setup.
    Mar 2012
    #2860
    yeah di ka nga hardcore, bewith lang hehehe.
audio set-up for beginners [continued]
