Results 651 to 660 of 1387
November 6th, 2017 02:31 AM #651
Told you magagawan ng paraan yan basta buo pa ang reflector bowl
I think na flash ka ng kasalubong mo dahil either dumaan ka sa pa ahon na surface ng kalsada and since malakas talaga ngayun ang HL mo kala ng kasalubong mo naka high ka well infact baka pa ahon or may bump lang ang surface nadaanan mo. Yung kay kruek18 at zechs mababa nga daw yung alignment ng cut-off nila form that shop so they have to raise it a bit.
Konting moisture sa headlight ay normal lang as long as mawala naman afterwards. Nagkaka moisture kasi ang headlight pag mainit ang car or headlight tapos biglang umulan. Pero pag parati na lang may moisture sa loob then pa check mo mga seal sa HL mo.
- Mar 2014
- 89
November 6th, 2017 03:33 AM #652Inquired about the g5 at xenon concepts. Worth it kaya ipa upgrade yun oem projectors ng impreza gh ko? Oem system is d2s 35w and philips 85122 bulbs. Might throw in a pair of new bulbs since nag color shift na to bluish yun current bulbs ko. Day and night difference kaya for 10.5k ?
November 6th, 2017 03:59 AM #653
G5 is an aftermarket replica hence the "R" at the end of the projector variant. IMO It would be a downgrade if you go from subaru oem projectors to a G5. Most people pay a lot of money to have an oem spec projectors, ballast and bulbs like yours. I'm not familiar with the impreza gh stock projectors but maybe kailangan mo lang ng lens swap into a clear STi-R lens ang upgrade your bulbs into a philips 85122xv c1 or osram cbi.
Contact Angelo Magtoto of redline autoworks. A lot of subbies na rin na punta dyan sa shop nya.
November 6th, 2017 07:23 AM #654
November 6th, 2017 08:49 AM #655
- Dec 2012
- 44
November 6th, 2017 10:15 AM #656Question lang, malaki ba difference ng NHK bulb ni Xenon Concepts compared sa Philips or Osram?
- Mar 2014
- 89
November 6th, 2017 12:05 PM #657
- Mar 2014
- 89
November 6th, 2017 01:25 PM #658
November 6th, 2017 04:05 PM #659
pag bago pa both bulbs halos di mo makita ang difference nyan. Magkakatalo yan sa lifespan. You'll see na mag color shift na ng maaga ang nhk if compared to osram or philips and medyo mataas ang UV ng mga aftermarket bulbs kesa oem so careful ka when running it with 55w ballast sisirain ng uv ang chrome coating sa loob ng projector.
If they say so po na palit projector then they know more than me but then you have to shell out a bit more on those two bit shops. And if price ang pag basehan then I think mas cheaper kay xenon concept. I'm not sure sa FXR projectors nya if from morimoto yan but I'm a fan of the fxr for oem spec projectors for its width beam pattern. Natandaan ko dati may isang shop ako tinanungan and sabi luma na daw ang fxr and q5 day ang bago. Natawa na lang ako dahil kahit luma na ang fxr projectors I will choose it over any q5
Ask them if pwede pa magamit yung oem ballast mo dahil oem ballast has faster startup time kesa mga aftermarket.
- Mar 2014
- 89
November 6th, 2017 04:09 PM #660Alright thanks bro. I doubt na mag ffit ang fxr sa gh ko. Ill keep the oem wiring ballast bulb set up and do only projector swap + maybe upgrade to the latest philips 85122 . My first choice is xenon concept since reasonable ang pricing nila.
