Page 68 of 139 FirstFirst ... 185864656667686970717278118 ... LastLast
Results 671 to 680 of 1387
    Mar 2012
    #671
    Quote Originally Posted by hypnos View Post
    Same lifespan with 85122? Hmm a bit expensive for a hundred more lux
    Same reason po why I buy a B&W hi-fi bookshelf speakers instead of cheaper HTIB systems like pioneer, kenwood or bose which ok if not excellent to some folks.
    Jan 2008
    #672
    Quote Originally Posted by D3nb3r View Post
    Pero bilib ako dun sa hi arc bulb na pnp ko dati, di nagbago kulay nun in 2yrs, daily lumalabas un auto ko, mga *least 1hr na night driving
    Sent from my R7plusf using Tapatalk
    Dec 2012
    #673
    pag bago pa both bulbs halos di mo makita ang difference nyan. Magkakatalo yan sa lifespan. You'll see na mag color shift na ng maaga ang nhk if compared to osram or philips and medyo mataas ang UV ng mga aftermarket bulbs kesa oem so careful ka when running it with 55w ballast sisirain ng uv ang chrome coating sa loob ng projector.
    Ahhh. Hintayin ko na lang mag color shift bago ako mag palit ng bulbs. Salamat boss
    Dec 2014
    #674
    Indeed sir. im sure it would blow others out of the water. what more if paired with s2k
    Nov 2011
    #675
    Ok naman so far ang Hella G5. Di lang aligned vertically (abot sa mata ng kasalubong na driver) and horizontally (not straight, sobrang naka focus sa left side, napansin ko yung step ng left projector is lagpas sa lane ko), inayos ko na lang. Also nag momoist sya sa both headlights, same part ng headlight.
    Aug 2012
    #676
    85122xv 2s1 = Xtreme Vision gen 2.
    85122xv c1 = Xtreme Vision gen 1.
    Sent from my ASUS_X00DDA using Tapatalk
    Mar 2012
    #677
    Quote Originally Posted by red_one View Post
    Nope.
    gen1 85122xv c1 +50%
    gen2 85122xv 2c1 +150%
    #678
    Hmmm. 4800K pala xv. Ok kaya to sa wet asphalt? Iniisip ko kung palitan ko na ballast ko to 35w then bulb replacement and maybe shroud na din since may konting deformation probably due to heat. Mapapagastos ata ako. hehe
    Aug 2012
    #679
    Nope.
    Nope.
    85122xv 2s1 is +150% also. See Philips data sheet.
    https://www.download.p4c.philips.com..._pss_enggb.pdf
    PHILIPS Xenon X-TremeVision Gen2 +150% D2S HID Xenon Bulb 85122XV2S1
    Amazon.com: PHILIPS Xenon X-TremeVision Gen2 +15% D2S HID Xenon Bulb 85122XV2S1: Automotive
    Mar 2012
    #680
    Nope.
    Edit: I was intrigued about this kaya I made some research. Actually same lang ata sila if compared(see pics below) now the reason why may dalawang bulb na same lahat ang specs sa isang site ng philips ay hindi ko alam.
    this is my gen1
    this the gen2
    comparison
    links:
    Philips Xenon X-treme Vision gen2 D2S HID Bulb (Single) | PowerBulbs
    Xenon X-tremeVision gen2 Xenon car headlight bulb 85122XV2C1 | Philips
    Products comparison
Planning on getting an HID retrofit
