Page 16 of 139 FirstFirst ... 61213141516171819202666116 ... LastLast
Results 151 to 160 of 1387
    Nov 2007
    #151
    Quote Originally Posted by Orv20 View Post
    Afaik pwede ibalik sa stock halogen ung headlights which is ganon sa stage 2 ni xenon so bolt on lang siya or plugn play.(parehas labg ba ung 2?hehe) Kay garyq wala ng bawian.
    Be careful lng kay garyq, pangit installation, kapag natatamaan ko ung wiring na connected sa comp.box sa ilalim ng manibela nawawala power ng buong sasakyan. Installation ng xenon is clean but hindi straight or pantay ung cut off(oc problems) dahil daw sa projector and maybe dahil hindi pantay ung terrain nung ginawa. If i can compare pics sana pero wala na sakin ung garyq retrofitted. Kay xenon walang moist but kay garyq 2 beses ako bumalik dahil sa moist.
    Happy naman ako sa stage 1 na ginawa ng xenon concepts. Not as bright as my monty's led but close enough. Cutoff is perfect naman like shown in my previous post.
    Havent seen any of garyq's works but afaik, retrofit lahat kay gary while bolt-on kay xenon.
    What will u choose between the 2? Gary na pangit installation but maganda buga or xenon na maganda installation but hindi pantay cutoff.
    Kung pwede ifuse ang 2[emoji51]
    Apr 2014
    #152
    Quote Originally Posted by JJB View Post
    Bolt on lang ba yung kay xenon?
    Nov 2007
    #153
    Quote Originally Posted by babybackrivs View Post
    Afaik, bolt on ang stage 1 ni xenon.
    Not sure if it matters kung bolt on or retrofit ang Stage 1 ng installers. Depends sa size projector na ikakabit
    #154
    ang alam ko kaya sinabing bolt on is dahil pasok siya sa standard h4 headlights without modifications done sa assembly, tulad ng h1(stage1) dahil maliit lang siya. pero ung mga d2s(stage2) at ibang malalaking projectors needs cutting sa assembly para mag fit, hence wala ng balikan to stock. correct me if im wrong.
    Dec 2014
    #155
    Quote Originally Posted by jtiro View Post
    That's right jtiro.
    Iba naman din ang plug'n play na sinasabi ni Orv20. Plug and play is just using an HID bulb on the stock halogen/projector without opening the headlight housing.
    bolt on din naman stage1 ni gary.
    kung may mali sa cutoff with xenon, contact mo lang sya ang have it fixed. It is imperative na pantay ang car when aligning the output.
    ganyan din experience ko kila gary, may loose sa wiring, sometimes it fires up, sometimes it doesnt. kaya hindi na ako nagpagawa sa kanila
    #156
    Too bad na pumapangit na pala installation ng hidretrofit. Might be because dumami na tao niya due to expansion ng business. Nung 2011 parang 2 lang tao niya nung nagparetrofit ako. Maayos lahat ng wiring and once lang ako nagpawarranty (konting water sa ballast).
    Mar 2012
    #157
    1. ask ko lang sa mga naka stage1 dito, worthy upgrade na din ba from stock? or much better value for money ung stage2 nila?
    2. ok ba ang nhk and hyluxtek brands? not familiar with these brands kasi.
    3. any idea magkano aabutin if morimoto projectors and Philips bulbs ang gagamitin? upon reading sa mga sites im thinking of going h1 or d2s setup from these brands, if kaya ng budget. if not, stick na lang ako sa budget packages nila.
    need your suggestions/opinions. salamat po sa sasagot.
    1. yung stage 1 ng hidretrofit or redline ay way better than stock halogens. But kung kaya ng budget ang stage 2 then go with it.
    2. Ok naman yan base sa mga nabasa ko. Actually ang lightwerkz sa US ay gumagagamit ng mga ganyang brand.
    personally naka gamit na ako ng nhk sa previous vehicle ko. yung isang ballast ko lasted less than 2yrs tho. pero baka mas ok na ngayun ang mga products nila.
    3. 400+ USD nagastos ko sa morimoto xb35 d2s ballast ko and philips xv c1 d2s plus morimoto mini d2s 4.0 projectors.
    Na tsamba lang napa daan kami ng US kaya naka bili ako sa TRS(The Retrofit Source.)
    pag pinagawa mo sa mga retrofit shop ang ganyang specs mga budget ka 35k above siguro.
    DIY lang ako kaya nakaka save[emoji16]
    Sent from my SM-J710GN using Tapatalk
    Mar 2012
    #158
    Yung mga aftermarket na makikita mo na threaded shaft like Morimoto mini H1 or mini d2s ay bolt-on din pero no modification needed sa reflector bowl.
    Yung mga oem projectors like rx350, murano, acura TL, evox-r or ang fx-r ay kailangan ng cutting kaya hindi sila bolt on.
    #159
    *D3nb3r
    thank you sir sa info. pag isipan ko pa kung stage1 or stage2, ipon mode din muna. pero kahit h1 lang ok na siguro.
    ok din sana mag diy if may gamit and knowlegeable.
    Mar 2012
    #160
    *D3nb3r
    daming video on how-to sa retrofitting sir. lahit sa website ng TRS daming sources ng info. From opening feadlights to alignments. But f ayaw mo pag practisan yung vehicle mo[emoji16] better sa mga reputable shops mo na lang ipa gawa.
Planning on getting an HID retrofit
