Results 471 to 480 of 1411
September 16th, 2009 06:39 PM #471
Mga sirs! Another question about polyurethane finish on wood (parquet) flooring...
In actual practice, what is the minimum recommended curing time for each topcoat of polyurethane (Hudson brand)? Sa website kasi ng Boysen, it says, "OVERCOATING INTERVAL: Recoat after 6 hours". It also says, "Allow 7 days to fully cure before allowing heavy duty use and 3 days for foot traffic abrasion." (http://www.boysen.com.ph/products.do?item_id=957).
Kasi po yung staircase namin (GF to 2F & 2F to attic, incl. mezz. landing & 2F Hallway), the contractor says na kaya daw matapos ito within the day (2 topcoats; sanding sealer was already applied today) and puede na daw itong magamit (meaning puede nang tapakan) at the end of the day. Refinishing lang po kasi ito and we have not vacated the premises while this project is ongoing. Yung mga kwarto naman ay overnight curing ang nangyari so no problem there I guess.
To clarify, wood slabs po ang staircase from GF to 2F except for the mezz. landing which is TNG (about 2 sqm ito). The 2F Hallway (about 4 sqm. area) is wood parquet and the staircase from 2F to attic is TNG. This whole area will be applied with Hudson Polyurethane Floor Varnish Topcoat tomorrow and I need your opinions ASAP sana...
TIA!!!
December 31st, 2009 01:00 PM #473
Can anybody recommend an architect and a honest contractor na naka based sa Manila? I am from Las Pinas.
Thanks.
- Feb 2010
- 7
February 13th, 2010 05:21 PM #474sa marikina ba kano bayaran dun?
pag magpapagawa ng bahay?
22k per sq.m. pa din ba?
March 4th, 2010 02:17 PM #475
Saan ba mura magpagawa ng matibay na kitchen cabinet? nagpa quote ako sa recommend ng interior designer, almost P1.8 million for a 20sq meter kitchen wala pa mga ref, stove etc...
March 4th, 2010 06:07 PM #477
March 4th, 2010 07:36 PM #478
P1.8M na kitchen? Huwawww! Di pwede magprito ng tuyo diyan!
Sa Wilcon ba wala nyan? Or kaya sa Home Depot.
- May 2006
- 1,668
March 4th, 2010 07:40 PM #479http://www.econeuro.com/Kitchen.html <- mukhang high end kasi. Kaya 1.8M.
Hataw yun interior designer nyo. Kelangan mo ata sabihin kung ano ang budget mo sa kanya.
March 4th, 2010 08:32 PM #480
Tesla Philippines
