Results 1,211 to 1,220 of 1659
May 30th, 2020 03:23 PM #1211
The pros did good. They removed the front face, air swing, drain runner, and blower. The fins were cleaned using detergent powder and rinsed using a pressure washer. Everything was reassembled well with no extra screws or broken clips. Now the whole living room area is cold again with the temp set at 26C.
Cleaning the unit in the bedroom will be more of a challenge because space is at a premium and the outdoor unit is more difficult to get to. A job for the pros then.
Sent from my SM-A605G using Tapatalk
June 1st, 2020 04:26 AM #1212
June 1st, 2020 04:31 AM #1213
- Oct 2006
- 6,091
June 1st, 2020 09:21 AM #1214
June 1st, 2020 09:28 AM #1215
We also want to get an inverter type as our next ac as we've heard nothing but positive things about it from consumers. However every technician (Carrier) we've had over to clean our non-inverter split types have advised us against it. Mas mahal daw irepair kung masira daw unlike the non-inverter split types. Kung di rin daw tama ang horsepower na mabili mo, di ka rin daw makakasave porket inverter (duh? Hehe). I don't know if they only said that kasi baka mabawasan sila ng work dahil di naman sirain ang inverter.[emoji2369]
Tsikot Forums mobile app
June 1st, 2020 09:34 AM #1216
June 1st, 2020 09:45 AM #1217
June 1st, 2020 09:47 AM #1218
- Oct 2006
- 6,091
June 1st, 2020 10:25 AM #1219I noticed some technicians and salesmen are a bit OA in my opinion when it comes to HP needed. Before I bought our AC the salesman asked for our floor area. He then said I needed a 1.5HP (which is the one I had in mind of getting), but suggested a 2HP to be safe. I thought it was overkill (and overbudget too). He said technicians may refuse to install and may void the warranty if they deem the area too big. I said, "eh di antayin na lang natin kung ayaw, isoli ko for a refund". He also suggested I a 2HP but non-inverter type, mas mabilis daw lumamig para tipid, which I refused as I felt he was pushing old, inefficient and likely non-selling items.
When the technicians came they also began measuring the floor area, and also warned me that I was I at their boundary (only less than 2sqm from their max limit). But they installed anyway. In reality, the room is now quite cold even when the AC is set at 24C.
June 1st, 2020 10:49 AM #1220
You also have to consider the heat sources in the room that the AC will cool. Window facing west? Kitchen with stove and fridge? Hyperactive kids? They all add up. An inverter does not make sense if the compressor is always maxed out.
Tesla Philippines
