Results 1,651 to 1,659 of 1659
- Jan 2007
- 2,452
September 27th, 2024 03:27 PM #1651Yup that's why I originally cited a theater/listening room.
There are ways to engineer around the problem like having an exhaust duct at the top of the room that plumbs back into the top of the area housing the indoor split; or simply having a taller enclosure with separate intake duct at the top to better utilize natural convection in the room.
On a well-running A/C this shouldn't be a big problem. A/Cs remove the humidity from the air and it falls down the drain pipe.Last edited by Dr.Kamiya; September 27th, 2024 at 03:30 PM.
- 53,883
September 27th, 2024 10:25 PM #1652
October 28th, 2024 11:33 AM #1653
Got a little busy this past weekend.
For months now, one of our outdoor units have been making intermittent screeching noises. It's quite far from the living spaces and wasn't actually bothering anyone so I thought it was something benign and didn't gave it much thought. Besides, the A/C was getting long in the tooth (12+ years) and I thought it was just something ageing machinery does.
But then a few days ago, the indoor unit started to shutdown after a few minutes and throw out an error.... with the Power LED blinking red.
Fearing the worst, I went out to look and discovered that the outdoor fan motor has seized up. My guess is that the system detected that the evaporator coil was overheating and it's what caused it to shutdown. I tried to rotate the fan by hand and it began to turn again, worse noises and all. But at least it was no longer shutting down.
Conceding that the temporary 'fix' wouldn't last, I removed the fan motor and disassembled it down to its rotor. I found that the aft bearing was all mangled up. While the front bearing was still technically ok, I decided to replace both.
Aft bearing:
Front bearing:
Went to a nearby bearing shop and bought a pair of SKF 6202-2RSH bearings:
Now, it runs and sounds brand new.... for its age.
All in, I spent less than P500.
Lesson learned is to not dismiss symptoms and abnormal operations, however benign, that can end up inconveniencing or costing you more later.
October 28th, 2024 12:22 PM #1654
October 28th, 2024 01:16 PM #1655
So far, so good. Haven't used it for a great length of time because we don't get many power outages longer than 20 minutes. But I still exercise it for 10-15 minutes every 2 months or so, just making sure it starts in an actual emergency. I alternate between gasoline and LP.
You can use any LP regulator that is used on stoves. What you need is the demand regulator that is one-piece with the carb. Less than 2k lang yung assembly and it's a bolt-on for the most part. You may need to adjust the air/fuel mixture for both gasoline and LP to work with your generator, but that's about it.
- 53,883
October 28th, 2024 01:24 PM #1656
October 28th, 2024 01:54 PM #1657
October 28th, 2024 10:35 PM #1659
Tesla Philippines
