Results 221 to 230 of 268
- Oct 2012
- 4,851
March 19th, 2021 11:58 PM #222
- Oct 2012
- 4,851
March 20th, 2021 01:47 PM #223Na connect ko na sa wifi ang printer... Mac driver for epson l805 works pero sa windows, hindi siya ma connect... weird! So for my windows laptop, i have to use the usb connection for printing...
Up next... checking the dslr photobooth software.... [emoji16][emoji16][emoji16]
March 21st, 2021 12:40 AM #224
Weird indeed ... usually it's Mac OS that have issues with WiFi printers ...
- Mar 2014
- 694
March 21st, 2021 04:04 PM #225I have Epson L3150 and was able to connect my Windows 10 desktop PC to it over the network. Pero binind ko yung printer MAC address to 1 IP para if di madetect automatically ng mga devices, they can manually add the printer by entering the printer IP.
- Oct 2012
- 4,851
March 21st, 2021 06:36 PM #226Did this route through windows... i set up the manual ip address and makikita naman ang ang mac ng printer but still it did not connect to the router...
may issue yata sa windows driver kasi when i use the mac driver, the same process sa windows, diretso2 connect nya...
- Mar 2014
- 694
March 21st, 2021 06:41 PM #227I just remembered I downloaded an Epson software that will launch a setup wizard and download the correct drivers. That actually worked for me instead of manually downloading a Windows 10 compatible driver from Epson Support page.
- Oct 2012
- 4,851
March 21st, 2021 06:57 PM #228
March 22nd, 2021 09:08 AM #229
August 26th, 2021 03:03 PM #230
I bought an Epson L3150 about a month ago (though, this will apply to any injket printer) and was scraping the internet on how to take care of it. Then I found this video and followed her advice. The darn tip works!
TL;DR,
Avoid using the printer's head-cleaning feature, especially Epson's Power Cleaning, as it wastes a lot of ink and reduces the service life of the ink waste pads. Instead, print out customized purge sheets so you can target only the color or printhead that needs cleaning. This also means, you're printing on paper and not spitting out the ink onto the ink waste pad.
You can find tons of purge files on the internet or you can even make them yourself using just MS Word (the video will show you how). However, be sure to use a purge sheet that matches the number of colors your printer can print. The L3150 has 3 colors + black (CMYK). Other printers may have different shades of the same color (5 colors + black).
Tesla Philippines
