Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
    Mar 2005
    I've got a very slow leak caused by a tiny shoe tack. Which is advisable to do i this case ? The "tusok" method or the cold patch method (requires dismounting the tire from the wheel) ?
    Wouldn't the "tusok" method make the hole larger? The hole is almost like just a pin prick .
    may malalagot na steel thread inside your rubber tire kapag "tusok" method which will cause "bukol" naman.
    Sep 2005
    Always use the cold patch method. Pag di pwede cold patch, time to get new tires. Don't ever use the "tusok" or "vulcanize (heated)" method. It will only ruin your tires.
    Quote Originally Posted by russpogi
    If your tire was applied with tusok method pwede pa ba irevert to cold patch?
    based on experience, better ang cold patch. yung tusok, minsan di perfect yung seal, at pag napudpod na ulit yung gulong, lumalabas yung tinusok nilang parang thread material na may adhesive. cold patch nasa loob lang at di na-e-expose sa labas. the internal pressure of the tire also helps in ensuring proper seal. hth ;)
    Sep 2005
    Quote Originally Posted by asterix
    Depends on the condition of the damage. Ideally yes.
    Jun 2005
    cold patch, matibay. yung gulong ko up to now, ok pa.
    Sep 2005
    mga sir, may kit ba na nabibilhan nung cold patch? saan po and how much? tia
    Nov 2003
    Tusok then patch
    tusok - seal to prevent corrosion on steel belts then
    patch - to prevent air leaking between layers.
    sakto na alambre ang gulong ko...cold patch din ako
vulcanizing: cold or hot patch?
