Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 90
    Nov 2017
    #51
    DriveGuard Run-Flat Tire by Bridgestone - YouTube
    Nice [emoji16]
    Quote Originally Posted by reymund View Post
    My rear right tire is consistently loosing its pressure. Everytime i go to gas station to inflate, the 3 other tires looks fine, ranging from 29 to 31 psi. The rear right tire pressure sits below 20 psi. what do you think could possibly wrong? the rubber or the valve?
    the front rubbers have been replaced but not yet the rear. anyone experienced this before? thanks.
    the valve can be easily checked with soap and water...
    if its not the valve.. there could be a nail or sharp object embedded on the tire. visit a shop to get a patch
    Feb 2005
    #53
    or may bengkong na yung lip ng mags mo like what happened to my mags nung binuhusan ng water with soap yung pito hindi bumula pero nung binuhusan yung lip dun na bumula ng husto dun pala sumisingaw although napaka konti ng singaw the tire loses about 1-2 psi every 4 days, kaya ang ginagawa ko every friday top up ng hangin and then on monday before going to work top up ulet.
    #54
    Quote Originally Posted by box_type View Post
    Usually nangyayari yan yun mga kinakabig na hook ng mga bulok na nag alingment/camber or naiihian ng aso nasisira talaga yun rubber doon sa lip ng mags.
    Feb 2014
    #55
    yeah check all around the bead for leaks. there might be corrosion on the rim which prevents good sealing. also most tire shops don't use the proper bead lubricant while installing
    Dec 2018
    #56
    Quote Originally Posted by red_one View Post
    This is the 12V AC-DC car power supply that I use. Max 10A or 120W. I do not need to turn on the car engine. I just plug this to AC outlet. It is universal voltage so can plug into 100-240V AC.
    Sir san mo po nabili to?
    Sent from my SM-J730G using Tapatalk
    Dec 2018
    #57
    Quote Originally Posted by ac3buddy View Post
    Okay na pla sir. Saw your reply on previous queries
    #58
    Quote Originally Posted by maxpedition View Post
    Tanong nagsimba ba o pakita tao lang [emoji28]
    I remember the Parish (?) Priest of St. Joseph Church in Baguio directing traffic after the 5pm mass.... Behaved ang mga drivers...😉😉😉
    #59
    I have a similar one ....
    I have a 12V power supply and I just connected a cigarette lighter outlet...
    Jul 2019
    #60
    Hi folks,
    I have a question regarding tire pressure gauge accuracy.
    I'm contemplating to buy a tire pressure gauge and I saw one in Blade Auto Center, its brand is OMP with accuracy of +/-1.
    What does +/-1 accuracy mean? Is that accuracy good?
    Many Thanks.
Tyre pressure
