Results 11 to 20 of 217
- 53,883
December 29th, 2021 01:26 AM #11
- Apr 2016
- 203
December 29th, 2021 07:51 AM #12I talked to a cousin yesterday. He told me "plug is inserting rubber on the hole. patch is like band aid. the problem with patch is repair is in the inside. but you tire still has a hole on the thread/outside. the thread are running on wet roads tendency is for water to seep thru the un plug hole there by causing rust to your steel belts which are sandwich between your patch and rubber threads. hence better plug kasi the seal is done inside and out. therfore water wont seep thru the hole. steel belts wont get rusted.".
So with cold patch inside only, won't it rust the steel belts since water can go inside without any plugs?
I know if I'd have cold patch done, they would pull the plug with pliers since as Glenn_duke mentioned, there is an extension inside they can't just grind it since it would be more difficult.
Also look at following.
What shop can do the middle one here (it uses a plug with patch in one like in the following)?
How To Properly Repair a Tire - YouTube
- 53,883
December 29th, 2021 08:03 AM #13there were no rust issues, back when belts were made of non-rusting materials like nylon.
- Sep 2021
- 872
December 29th, 2021 10:04 AM #14Maybe one shouldn't fret too much about this.
If, (and by the time it takes) those belts to start to corrode it would probably be high time to replace the tires na rin anyway. Tipong thousands of km na rin natakbo or over 6yrs na rin yung gulong from manufacture date.
That is, if you have a good quality tire (not necessarily expensive) naman and don't abuse it sobra. As for those cheaper ones from China that look similar (on the outside) but actually differ in terms of quality (its what's on the inside that really counts!), ewan ko lang...
December 29th, 2021 10:08 AM #15
TL;DR Use the repair method that makes the most sense for your situation. Use cold patch if available. For quick field repairs, string plugs will do. Either methods comes along with caveats.
During the 2000s, I had a 100cc scooter and my tire repair kit consists of string plugs and a hand pump. I also brought along Slime tire sealant. These are specifically meant for quick field tire repairs. However, scooters have only about half the tread depth (or even less) than that of a car tire so the string plug would start leaking as the tire wear down near the end of its life. Those Metzeler scooter tires were the bomb back then because of their grip, but they do wear down quick. String plugs made sense because by the time the plugs starts to leak, it's almost always time to replace the tire anyway. The Slime just prolongs the inevitable.
Back to today, Dec. 2021, the last puncture on my Innova was around 2 weeks ago. The vulcanizing shop just repaired it with a string plug. I would've wanted a cold patch but weighing how old the tire is (43k KM), I agreed on the more temporary repair. It's holding its own at the moment but I'm planning to replace the tires soon.
Now, if the circumstances were better, I'd prefer a cold patch.... the "German patch", as the local vulcanizing shops know it. In my experience, these prove to be very reliable down to the last millimeter of tire tread. The downside is, it is a lot more involved, takes five times as long to fix, and costs more per hole to patch.
- Sep 2021
- 872
December 29th, 2021 10:19 AM #16Ay naku, share ko lang, never, ever use these, even yung mga "instant tire repair" in a can.
Sisirain niyan tire mo. When you pull it off the rim for a proper repair na, kadalasan irrecoverable na. The goop is stuck and messed up na sa loob. Replace gulong situation na yun. If you insist on keeping it, you'll never be able to balance it properly na rin.
Pang in cases of extreme necessity/emergency lang siguro talaga usefulness nito (ex. lady driver alone in a dangerous place), pero yung tipong tinatamad ka lang magpalit ng gulong, most often you'll regret it.
- Sep 2021
- 872
December 29th, 2021 10:31 AM #17Agree.
For example, if you have the misfortune of having 2 flats at the same time, medyo mahirap naman ata maging choosy under those circumstances!
One other thing to consider din with tires na na-vulcanize na is you won't be able to trust the tire's speed rating na rin (bec. honestly, unknown yung quality talaga ng repair. Walang pang test nun).
Not too much of an issue with me though kasi mababagal naman yung mga cars koI doubt they'd EVER even come close to the maximum permissible sa "S" speed rating, even when they were freshly broken in LOL
- 53,883
December 29th, 2021 10:36 AM #18when i get a flat tire within the civilized world,
i just ask the local yokels, or a passing taxi driver or tricycle driver,
to do the tire replacement for me.
then i slip 'em a hundring bucks. both happy kami.
it's not that tiring, watching him do the huffing and puffing.
not that i do not know how!
medyo hassle kasi magpalit ng gulong , dressed in your conference best.Last edited by dr. d; December 29th, 2021 at 10:43 AM.
December 29th, 2021 11:07 AM #19
Used it twice only during my scooter days. I know about how it corrodes the inside of a metal rim, but mostly it's superficial (ie. the paint flakes off).
As for the goop in the tires, in my situation, palitin na rin by that point so not a major issue.
But yes, don't use these products in your vehicles unless you're out of other options. If you do, clean it out as soon as possible or palitan na yung tire (in case it's already worn out).
- Sep 2021
- 872
December 29th, 2021 12:44 PM #20Oo naman. I hate changing tires. Never mind the exertion involved, ang dumi dumi mo pa pagkatapos.
Bwiset na mga scissors (diamond) jack na OEM for almost all cars and even SUVs.
Ok, I know negligible naman yung weight & fuel savings if you put a bottle or alligator jack in your vehicle, pero ayaw ko ng sangkatutak na gamit sa sasakyan eh, so when necessity calls, eh ayun, tiis using what you have (kasalanan ko eh).
Tesla Philippines
