Results 121 to 130 of 2045
- Apr 2009
- 72
July 18th, 2009 11:45 AM #121parang may leak ung window sa likod. kaya pag tumatakbo naririnig mu yung hangin sa labas..
July 19th, 2009 04:52 PM #122
- Dec 2008
- 108
July 20th, 2009 07:17 PM #123
July 21st, 2009 05:42 AM #124
- Mar 2009
- 154
July 22nd, 2009 11:29 AM #125
July 24th, 2009 12:16 AM #126
July 24th, 2009 12:41 AM #127
No need to worry sa 3.2 engine my triton is the first release dito it is a 2005 limited edition since then until now im running 60K na wala pa din problema and im using my truck hard on trail and on city hehehehehehehehe the only problem we encounter with the 3.2 engine is the SCV because pag gumamit kayo nag medyo maduming deisel madali siyang masira at the same time hindi pa siya pwede sa bio deisel that go above 3% bio. well tested na ang 3.2 dito for the triton.
- Dec 2008
- 108
July 25th, 2009 01:03 PM #128
July 25th, 2009 01:09 PM #129
Sir, baka eto yung tinatawag na sanitary check valve?
not sure though...
SANITARY CHECK VALVES OVERVIEW
The DSV® is an in-line spring-assisted check valve designed to prevent flow reversal in industries with strict cleanliness codes. To accommodate various piping arrangements, the DSV® is available as a “Vertical” or “Horizontal” valve. The DSV®, with a 316L stainless steel body and seat, is fastened with a quick release clamp and elastomeric body seal to permit fast and easy access to the internals. The internal surface finish is 25 Ra while the disc and seat are lapped to provide excellent shutoff.
[SIZE=2].[/SIZE]
[SIZE=3]DSV[/SIZE]®[SIZE=3]- HORIZONTAL[/SIZE]
[SIZE=3]DSV[/SIZE]®[SIZE=3] - VERTICAL[/SIZE]
SANITARY CHECK VALVE APPLICATIONS
Applications:
- Liquids
- Gases
- Steam
- Food
- Beverage
- Pharmaceutical
- Bio-Tech
- Ultra Pure
- Jul 2009
- 4
July 27th, 2009 11:26 PM #130hello,
does anyone here owns a MS 4x4 GLS 2.5L M/T?
my experience is whenever, i shift from 1st gear to 2nd gear, i hear a thud sound, seems like i released the clutch prematurely but in fact i'm not even releasing the clutch even a bit when it happens.
anybody here who got same experience? what did you do?
thank you
Tesla Philippines
