Page 13 of 205 FirstFirst ... 3910111213141516172363113 ... LastLast
Results 121 to 130 of 2045
    Apr 2009
    #121
    parang may leak ung window sa likod. kaya pag tumatakbo naririnig mu yung hangin sa labas..
    Dec 2008
    #122
    Quote Originally Posted by dsjamd View Post
    Mine is 3.2 gls se. Nafeel ko na yung thud sound when starting but i dont mind
    it. Eto na naiirita na ako right after 5k km check up, napansin ko na yung sound ng makina ay may parang butas na tambutso and feel ko yung vibration
    hanggang loob ng car. Nadidinig ko ito between 40-60 km/hr or between 10k-20k rpm. Any similar experience and advice before na dalhin ko sa casa?
    Nasolve na ng casa yung unwanted sounds na naririnig ko. Inilagay nila sa computer diagnostics yung makina and naitune up lang nila and I'm satisfied
    with the result without paying anything.
    Dec 2008
    #123
    nice to hear that sir may i ask what casa po ginawa? im happy that even though there are issues on the montero mitsubishi phil can address them..
    Dec 2008
    #124
    Quote Originally Posted by reloaded_acer View Post
    Sa citimotors alabang. They also inspected the exhaust system and walang
    nakitang anumang diperensya.
    #125
    sir ask ko lang anu daw naging problem bkit meron annoying sounds from the engine. di ba sirain yun 3.2 engine, we are using 3.2 strada kasi , bka in the future ma encounter ko din yan, worried lang. meron ding bang naka experience nito
    Dec 2008
    #126
    Quote Originally Posted by marktriton View Post
    Hindi naman sinabi ng mechanic kung ano ang naging problema. We did compare the sound of the engine with the other 3.2 sa casa and may difference nga yung sound sabi niya. Now happy uli ako lalo na when I'm driving at SLEX smooth na smooth.
    Jun 2008
    #127
    No need to worry sa 3.2 engine my triton is the first release dito it is a 2005 limited edition since then until now im running 60K na wala pa din problema and im using my truck hard on trail and on city hehehehehehehehe the only problem we encounter with the 3.2 engine is the SCV because pag gumamit kayo nag medyo maduming deisel madali siyang masira at the same time hindi pa siya pwede sa bio deisel that go above 3% bio. well tested na ang 3.2 dito for the triton.
    Dec 2008
    #128
    Quote Originally Posted by dadz View Post
    hi sir,
    sorry for my ignorance but what is SCV?
    Feb 2007
    #129
    hi sir,
    Sir, baka eto yung tinatawag na sanitary check valve?
    not sure though...
    SANITARY CHECK VALVES OVERVIEW
    The DSV® is an in-line spring-assisted check valve designed to prevent flow reversal in industries with strict cleanliness codes. To accommodate various piping arrangements, the DSV® is available as a “Vertical” or “Horizontal” valve. The DSV®, with a 316L stainless steel body and seat, is fastened with a quick release clamp and elastomeric body seal to permit fast and easy access to the internals. The internal surface finish is 25 Ra while the disc and seat are lapped to provide excellent shutoff.
    [SIZE=2].[/SIZE]
    [SIZE=3]DSV[/SIZE]®[SIZE=3]- HORIZONTAL[/SIZE]
    [SIZE=3]DSV[/SIZE]®[SIZE=3] - VERTICAL[/SIZE]
    SANITARY CHECK VALVE APPLICATIONS
    Applications:
    • Liquids
    • Gases
    • Steam
    Industries:
    • Food
    • Beverage
    • Pharmaceutical
    • Bio-Tech
    • Ultra Pure
    hope this help.:peace:
    #130
    hello,
    does anyone here owns a MS 4x4 GLS 2.5L M/T?
    my experience is whenever, i shift from 1st gear to 2nd gear, i hear a thud sound, seems like i released the clutch prematurely but in fact i'm not even releasing the clutch even a bit when it happens.
    anybody here who got same experience? what did you do?
    thank you
ISSUES FOR THE MONTERO SPORT. Please post them here.
