Results 4,981 to 4,990 of 5006
February 11th, 2017 10:58 AM #4981
- Jul 2016
- 939
February 11th, 2017 11:32 AM #4982New cars nowadays uses CAN bus system to communicate. The BCM sees an open or too little resistance in the brake light circuit so it will throw a code. Maybe in mitsu system and others, BCM will ask ABS module to light up the abs light to alert the driver.
Old school way is to add resistors to an led bulb or buy BCM friendly led bulbs to fool the BCM.
High tech way is to program the BCM to disregard brake light open circuit detection.
On a side note, check your brake pedal switch as well. Maybe it's not sending brake pedal signal to bcm...
- Nov 2008
- 81
February 17th, 2017 04:31 PM #4983sorry sirs , late reply, for sir baludoy, it has not happened again but am taking the lead of sir zix888, saw a similar predicament on you tube and will look at replacing the suction control valve, medyo mahal, 9500 sa el dorado but replacement pwede diy, thanks sir zix888
- May 2014
- 27
February 19th, 2017 01:58 PM #4984bro same problem din ng TPMS ko loss signal all tire, reset ko na sa MID #10 button then remove na rin negative terminal ng battery for 10 minutes, loss signal pa rin ang tpms ko, try ko hanapin yung fuse ng tpms pero hindi ko makita, san ba location non at ilang amp. ang fuse, nakita ko na yung black box tranmitter nya with antenna but no fuse akong nakita
- May 2014
- 27
February 19th, 2017 02:00 PM #4985bro same problem din ng TPMS ko loss signal all tire, reset ko na sa MID #10 button then remove na rin negative terminal ng battery for 10 minutes, loss signal pa rin ang tpms ko, try ko hanapin yung fuse ng tpms pero hindi ko makita, san ba location non at ilang amp. ang fuse, nakita ko na yung black box tranmitter nya with antenna but no fuse akong nakita[/QUOTE]
- Feb 2011
- 51
February 3rd, 2018 10:37 PM #4986What is the latest map version for our 2011 montero? Sino po ang may copy? Wala na pala sa INAV update site for our unit
Thanks in advance
February 5th, 2018 08:26 AM #4987
- Nov 2017
- 6
March 31st, 2018 07:01 PM #4988Sir, ang auxiliary fan ba natin may hi and may low speed? Minsan kasi mahina at minsan naman mabilis ang ikot ng fan. 1 month old pa lang yung new valeo aux fan. Salamat.
- Nov 2018
- 1
November 2nd, 2018 04:54 PM #4989
- May 2013
- 1
November 7th, 2018 11:57 AM #4990
Tesla Philippines
