Page 5 of 209 FirstFirst 1234567891555105 ... LastLast
Results 41 to 50 of 2085
    #41
    From a Viber thread...
    zero viz nuvali area.avoid CALAXand SLEX at least from binan to sta rosa.hirap mag drive basta basta na lang may humihinto as daan kahit Expressway lalo yung walang tubig ang windshield wiper.better uf you dont drive coming to or from these areas.keep safe everyone.
    Oct 2017
    #42
    Hello from QC. My true qc.
    Jan 2008
    #43
    Tsk tsk, will the Philippines explode? Kasi Pinatubo barely umabt sa MM, pero eto abot Baguio na
    Anong barely umabot? Eh ang daming abo na ibinagsak yan pinatubo sa metro manila.. daming bubong ang nabulok after gawa ng kasabay na pag ulan.. may bagyo pa yata nuon eh..
    Dec 2019
    #44
    To our dear Toyota customers:
    Due to the recent ashfall from Taal Volcano, please be advised of the following immediate measures to protect your vehicle/s :
    1. Please wash your vehicles with pressurized water to remove ash from the vehicle's body, but please do not wipe the vehicle while spraying water to avoid scratches on the vehicle's body
    2. Please repeat if vehicle continues to be covered with ashfall
    3. If engine room is affected, please bring your vehicle to your nearest Toyota dealer for proper engine cleaning.
    Please also protect yourself from the ashfall while cleaning your vehicle by wearing protective gear like raincoat and mask.
    Please contact our dealer if you have questions.
    Thank you
    Dec 2019
    #45
    Don't use aircon daw
    Due to the recent ongoing ashfall from Taal Volcano please be advised of the following measures to protect your airconditioning system:
    If you experience heavy ash fall, kindly refrain from using your Split type airconditioner and window type airconditioners.
    Continued use with heavy ashfall will result in the clogging of the outdoor condenser coil, which in turn will cause overheating of the compressor and overall airconditioning system.
    Should you really need to use your Air Conditioning units, kindly be advised to wait until the ashfall decreases, then clean the area where your condenser is located before you resume air conditioner operation.
    Dec 2009
    #46
    Volcanic ash is detrimental to jet engines, no flights to airports will be possible
    Madedelay ang deliveries from shopee & lazada
    #47
    Nasa PH ka pala?
    Oct 2017
    #48
    Nasa PH ka pala?
    Yes sir! flight out tomorrow dapat pero by the looks of it, my vacation will be extended.
    #49
    i remember a popular episode in "air crash investigation".
    the jet liner's engines died, because it sucked in the fine ash from the indonesian volcano that was showing what it was made of.
    #50
Taal Eruption 2020
