Page 79 of 142 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 781 to 790 of 1411
    Nov 2017
    #781
    Maganda nga yan Sir Max if one has the equipment, sakin mano mano lang, division lang naman ng rooms sa 2F
    Sent from my Mi A1 using Tapatalk
    Mag wall stud ka 2x3 space *16" vertically. You can use fiber cement board instead of gypsum board.
    Jan 2016
    #782
    Thanks Sir Max, I watched a YouTube installation and saw that the 16" spacing is the sturdiest, designed to carry tiles for t&b.
    I actually plan to do a built in closet on this wall, thinking it would further boost the strength of this wall, am I right to assume this?
    #783
    Correct...added corners & depth from built-in cabinetry can reinforce walls, sir.
    Jan 2016
    #784
    Thanks Sir Travs, I was scanning the net and saw some composite walls made with mortar and EPS, it has T&G for easy joining and does not require plastering anymore, seems a lot easier, can this be supported by the slab alone? I think I read 65kg/sqm.
    BTW, the floor is 12mm thick at 3k psi.
    #785
    Check wall load assumptions w/ your designer, sir. Slab thickness & design mix alone are not enough data.
    Also, plan out how you're gonna approach electrical & plumbing prep. Those T&G joints are best left shown. Filled, they will likely crack after a while.
    Pair rigid w/ pliant materials, if you plan to have seamless walls remain so, longterm. Therefore, cement boards like Hardiflex go better w/ wood, & Gypsum w/ metal.
    Jan 2016
    #786
    Uh-oh, I read that gypsum is not as hardy as ficem, I was actually thinking of hardiflex on metal
    #787
    Not saying you can't...just pointing the ideal.
    Jan 2016
    #788
    Thanks [emoji4] Sir Travs [emoji106]
    #789
    Anytime, papi sir!
    Jan 2016
    #790
    Masters Trav and Max, pwede ko ba lagyan agad ng boysen plexibond ang freshly done plaster? Or may waiting time? According to their website, need 14 - 28 days curing for fresh concrete, but I think it refers to slab, firewall ang lalagyan ko sirs. Kindly advise me, thank you.
House Constuction [Merged]
