Results 21 to 30 of 34
December 27th, 2013 08:32 AM #21
You need extra care for your punctured tire, 175kph speed is not a joke for a good tire then how much more to your punctured tire!
To ease some of your burden, subject your tire to a pressure test at least 80% (between 40-44psi, I guess) every six months or once in a while. If it doesnt show any problems then continue using but avoid high speed as much as possible.
- Aug 2013
- 44
August 21st, 2016 10:06 AM #22I just noticed this puncture sa sidewall. 255/55/r18 tire ko if it makes a difference. Safe to use pa kaya ito? Worried lang since we'll be going to Baguio next weekend. If ever papalitan, at least dalawang gulong? Ouch!/
- 53,883
August 21st, 2016 10:11 AM #23
August 21st, 2016 10:37 AM #24
Palitan mo na yan bro, delikado yan sumabog sa high speed sa highway.
August 21st, 2016 11:48 AM #25
Nasilip na ba sa loob? Before na gutter ako tuklap din gaya niyan.
Pero mababaw lang, no issues inside.
pinang spare tire ko na lang.
- Mar 2016
- 48
August 21st, 2016 01:59 PM #26Kapag sa sidewall yung damage, hindi na ba talaga pwedeng irepair? And unsafe ng gamitin? Happened to me din pero nilagyan lng ng patch.. nagcheck ako ng tire pressure kanina and it dropped from 35 to 32 in two weeks..
- Aug 2013
- 44
August 21st, 2016 02:30 PM #27Thanks sa replies. Mababaw lng naman. Around 3mm max siguro at hindi naman na flat. Saan po kya pwede ipa check ang loob ng gulong? Vulcanizng or mga tire seller?
Sent from my LG-D855 using Tsikot Forums mobile app
- Aug 2013
- 44
August 21st, 2016 02:32 PM #28Dumaan din ako kanina sa tire shop near our house. Sabi nung bantay nila dun, ok lang daw yun at makapal naman ang mga side wall.
- Jun 2015
- 2,751
April 7th, 2022 10:25 AM #29Not sure if I have a hidden puncture but what are the possible causes if your tire loses about 1 psi per day?
I have this 1 tire that slowly loses around 1 psi per day. A few weeks ago, nabunot ang metal na pito while topping up the air sa gas station. I thought mawawala na ang problema after I had it replaced. Kaso hanggang ngayon nagbabawas pa rin ng hangin. From 35 last Sunday afternoon, 32.5 na lang siya by Wednesday night.
Ano ba ang dapat kong ipa-check aside from punctures? Nagli-leak din ba ang hangin sa edge na in contact with the rims? Made-detect ba sa mga roadside vulcanizing shops ang mga ganitong leak?
Aside from the spare, all my tires are 4 years old. The tire in question is currently on the rear passenger side.
April 7th, 2022 10:51 AM #30
Kung walang puncture at hindi pa more than 8 years ang gulong, the tire bead seating on the rimmight have some dirt or obstruction kaya may sumisingaw. Have it (rim) checked and cleaned and put some water or water with soap before re-installing the tires.
Pito also sometime need na palitan. Inflate sa max tire pressure at usually makikita issue sa rim at sa pito.
Tesla Philippines
