Results 11 to 20 of 34
- 53,883
December 5th, 2013 01:02 AM #11use the spare. spare the punctured-but-repaired tire. file it under "tire rotation", which is what we should be doing, anyway.
- Aug 2012
- 102
December 26th, 2013 04:10 PM #12mga sirs, na punctured din yung gulong ko, hindi naman sya na flat at hindi ko rin alam kung kailan ito nangyari
tinignan ko lang yung gulong ko kasi parang may dumi, pag hawak ko pako pala sya. pag ba pinavulcanize ko ito safe pa gamitin?
pag tinanggal yung pako dun palang ba sya mafflat?
salamat po sa mga sasagot.
eto po yung picture nung pako sa gulong ko.
December 26th, 2013 04:17 PM #14
^^ Pa vulcanize mo na lang as soon as possible. Medyo alanganin lang ako dahil malapit na sa sidewall.
- Aug 2012
- 102
December 26th, 2013 07:07 PM #17
Ano yung luto type?
Yung tusok, "pasak" yung term nila.
December 26th, 2013 07:38 PM #18
Ung may apoy sa ibabaw luto. Ung isa naman tutusukin pra pasakan ung hole sa tire mismo. Wala ng tanggalan, bsta tusok lang.
Sent from my iPhone using Tsikot Car ForumsLast edited by H1Tman; December 26th, 2013 at 07:41 PM.
- Aug 2012
- 102
December 26th, 2013 11:00 PM #19thanks lowslowbenz!
buti nasabihan mo ko, hehe wala pa naman ako alam sa pagpapavulcanize baka mag oo lang ako hehe.
- Nov 2009
- 3,503
December 26th, 2013 11:19 PM #20Nasisira ang timpla ng goma sa luto type, lumulutong at humihiwalay sa steel belt katagalan.
TS, since you mentioned the tire was heated and unsure if the belt was not damaged, better use it on the rear or as a spare na lang. BTW, im just curious where did you reached 170? Aside from Sto tomas to san pablo near villa escudero, high speed run above 140-180 i can do at San fernando after Milaor then portion of Iriga/Albay. Cam Norte bitukang manok is much of an "initial D" run, while rest of the road are unforgiving for the tires/suspension.
Tesla Philippines
