Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
    #31
    Quote Originally Posted by 1D4LV View Post
    san yung biyak? sa sidewall o sa surface?
    kung sa surface, patapalan mo yung loob as in parang vulcanized.
    kung sa sidewalls, delikado.
    sa sidewall sir eh, so di ko muna pwede ibyahe ng malayo? or pag pinatapalan ko po ba? will it work?
    #32
    To thread starter / Manilablock
    Replace all 4.
    The tires are the only things connecting your car to the road.
    Worn/old tires will increase the likelihood of accidents on the road, whether it be due to exploding tires or poor braking performance.
    Hindi worth it yung pagsave ng konting pera kung malaking aksidente yung possibleng maabutan.
    Get new, decent quality tires while you're at it.
    Adding to what sir number001 said, since 2 of the 2010 tires are worn, use the 3rd 2010 tire as the spare and dispose of the rest.
    #33
    looks like ganito retz
    #34
    Quote Originally Posted by d'flash View Post
    sir i bought my brand new tyres nitong march lang, sa kasamaang palad, napasabak ako sa lubak at nung nag carwash/wax ako at tire black, napanasin ko na nagka biyak yung front tire ko, mga half inch siya, pinacheck ko sa tire shop, sabi ok lang daw yun, para daw daw sa peace of mind ko, susunigan daw nila para matapalan, okay ba yun? di pa papangit gulong ko? may lakad kasi ako sa sat eh, medyo malayo ang byahe di kaya biglang sumabog gulong ko nun? btw nankang 195/50/15 yung tyres ko.
    In my opinion, that's the problem with the cheaper chinamade tires.
    After all the abuse we've put our cars through, none of our Yokohamas/Bridgestones (Yoko A.Drive/A300 / Bridgestone Turanzas) have had major cracks/bumps.
    It's always your call kung itutuloy mo yung lakad. But better safe than sorry. I'd replace the tire na.
    Edit: Can't see the picture
    Oct 2011
    #35
    repost ko lang pix ni d'flash:
    #36
    thanks bro, sample pics lang yan, same ng nangyari sa tire ko.
    #37
    ^ Depends how deep the cut is into the sidewall. Will a thin ruler fit through the crack so you can check? (Not sure if there are other alternatives on how to check how deep the cut really is)
    Based on readings from the internet, <basta> hindi pa umabot/nagexpose ng cord, parang okay pa naman. Just be a little more careful/don't push the tire so hard I guess?
    Mar 2012
    #38
    looks pretty bad since nasa sidewall area na nga.. ok sana kung sa surface.. pede pang mavulcanize.
    #39
    Quote Originally Posted by mda View Post
    wala naman nakitang thread at nung chineck ng tire shop susunugan lang daw, para magdikit ulit, sir mda dapat ko bang bawasan na lang yung psi ko? from 30 to 28?
    #40
    they actually enforce the check lists? eh bakit nakak register pa mga PUJs?
    Baka nanghiram sa kakilala na bagong plait. Ibalik lang ulit mamya after registration.
    Baka ganun din sa makina! :rofl:
Nothing Lasts Forever...and Tyres Are No Exception
