Page 247 of 371 FirstFirst ... 147197237243244245246247248249250251257297347 ... LastLast
Results 2,461 to 2,470 of 3710
    Feb 2011
    #2461
    Quote Originally Posted by siopaonatoasted View Post
    Coolant pa ba ang nakalagay sa radiator mo or just plain distilled water?
    How sure are you na sa radiator nga ang may problema?
    Im using 50% water and 50% coolant. It was diagnosed in the CASA as having radiator leak coming fom the fins. The CASA is charging P4.5 k for the overhaul.
    Feb 2013
    #2462
    Palit ka na radiator.
    Jun 2010
    #2463
    Quote Originally Posted by astra22 View Post
    Mga bros, i have a problem with the radiator of my 2003 Crosswind XUV. Nagbabawas na sya ng tubig. Ang estimate ko isang baso ang nababawas every morning. Kaya pa ba ng overhaul ito or palit na. Baka may suggestions po kayo ng reputable shops in las pinas alabang area for the overhaul. Thank you.
    Sir, may leak lang yan. Mine is also 2003 model and I've done repairs too on my radiator. Nagpa-overhaul lang ako and repair with "tingga" para sa tagas. Kalokohan po iyung 4.5k na overhaul =)). Sagad na siguro ang 1500 para sa maayos na gawa. Though I can't recommend any shops for you since I'm from Cubao area. Hanap ka lang sir ng reputable shop. Madali lang yan.
    Take note nga lang na sa fittings lang ang naging tagas ng sakin. Madali lang ma-repair ang ganun. The problem is, kung sa fins nga yan, ibang usapan na yun. From what my suki shop said, kapag doon daw ang tagas, maaaring palitin na nga. Better have it checked first.
    Jan 2013
    #2464
    magkano po bagong radiator? baka onti na lang dadagdag mo sa 4500 bagong radiator na
    Feb 2011
    #2465
    Good suggestion bros! I was able to have my radiator overhauled. We found out that the leak was not really from the fins. I only spent 1k for the overhaul and repair. I hope this will be a good long time fix. Been using my crosswind for 3 days now without refilling the radiator!
    Jun 2010
    #2466
    Good job bro. Saan mo pinagawa?
    Feb 2011
    #2467
    Had it overhauled and repaired at Prens in Alabang. Almost halfday to finish the job.
    Jun 2013
    #2468
    what pair of speakers ang magandang ipalit sa front and rear ng xwind xuv 03 model?? papalitan ko na kasi yung stock, pangit na ng tunog. naghahanap ako ng punchy bass replacement speaker for front and rear, 4inch sa front and 6.5inch sa rear. ayaw ko na sana lagyan ng subwoofer.
    Jun 2010
    #2469
    Quote Originally Posted by Rob Echevarria View Post
    I upgraded to Sony explod. Pero sa tingin ko may limitation talaga ang speakers set-up natin. Yumayanig kasi yung pinto kaya hindi solid ang bass kahit gaano pa kalakas ang speakers mo. Unless magpa-install ka siguro ng insulation or sound deadener baka may improvement. Kaya in the end, I still resorted to an amplified bass tube para minimal lang ang space consumption. Oks na oks ang tunog niya for 6k.
    Apr 2008
    #2470
    Quote Originally Posted by kafph2000 View Post
    if defined bass ang gusto u need the subs tlga.may limitation parin ung kayang ibuga na frequency ng speakers sa pintuan kahit ung mumurahin na SW with murang ampli malaki na difference
Isuzu Crosswind Owners Thread [continued]
