Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2015
    What would be the minimum battery voltage needed to start the engine?
    I have a 02 Crosswind XTO
    Sent using Tapatalk
    9V. Pero hirap na sya. I replaced battery after.
    Sa 10V, its a few weeks left. Assuming usual first start... Not multiple straight starts
    Quote Originally Posted by istan View Post
    diba * 9v tulak na ito diba ^_^
    Nastart ko pa at 9V. Pero may dasal na kasama. Hahahaha!
    Jul 2016
    Quote Originally Posted by XwindXTO View Post
    Sent using Tapatalk
    Depende sa starter motor, cabling at compression ratio at number of cylinders...
    Pero usually 8.5v pataas kaya pa.
    Quote Originally Posted by Janemar View Post
    i see, sakin pala naalala ko pag ON ko ng auto eh totally wala na umilaw sa dash. pero nakuha pa sa tulak ^_^
    May 2009
    pero sa naranasan ko minsan e 11.5 volts hindi na kaya...different car brand though. after chinarge ng 8 hrs ayun ok uli. sabagay beyond the service life na yung battery kaya pinalitan din few days after charging.
    Aug 2012
    9V while cranking is okay. Normal na bumaba ang voltage during cranking.
    9V at rest (not cranking) is already dead battery. 10.5V is 0% charged.
    Sent from my D5833 using Tapatalk
    Kaya pa ba madala sa digital charger ang pag charge ng mga naka 9v na batt para bumalik sa optimum or satisfactory condition?
    to be or not to be, that always confuses me!
    Sep 2013
    Quote Originally Posted by red_one View Post
    It's not voltage that determines whether you can start the car, but it's the starter's ability to deliver amperage. A volt meter will only give you a rough idea of the state of charge assuming that the battery is known to be in good condition. An average car batt produces roughly 400 to 500A to start the car. Assume the car batt is 9V while cracking but the ampere is only 70 so di pa rin mag-start ito
Minimum battery voltage
