Page 1 of 3 123 LastLast
Results 1 to 10 of 23
XwindXTO Minimum battery voltage February 7th, 2017, 12:08 PM
istan Re: Minimum battery voltage February 9th, 2017, 02:56 AM
ninjababez Re: Minimum battery voltage February 9th, 2017, 05:27 AM
istan Re: Minimum battery voltage February 9th, 2017, 11:38 PM
ninjababez Re: Minimum battery voltage February 10th, 2017, 12:45 AM
miked Re: Minimum battery voltage February 10th, 2017, 02:12 PM
Janemar Re: Minimum battery voltage February 9th, 2017, 11:49 PM
red_one Re: Minimum battery voltage February 10th, 2017, 03:55 PM
kimbon Re: Minimum battery voltage February 10th, 2017, 05:53 PM
red_one Re: Minimum battery voltage February 10th, 2017, 06:17 PM
red_one Re: Minimum battery voltage February 10th, 2017, 06:19 PM
kimbon Re: Minimum battery voltage February 10th, 2017, 06:25 PM
baludoy Re: Minimum battery voltage February 10th, 2017, 05:27 PM
red_one Re: Minimum battery voltage February 10th, 2017, 06:12 PM
red_one Re: Minimum battery voltage February 10th, 2017, 06:59 PM
kimbon Re: Minimum battery voltage February 10th, 2017, 07:24 PM
kai s. Re: Minimum battery voltage February 10th, 2017, 09:43 PM
kimbon Re: Minimum battery voltage February 12th, 2017, 11:26 AM
pyramid00 Re: Minimum battery voltage March 27th, 2017, 08:13 PM
JJB Re: Minimum battery voltage February 11th, 2017, 12:01 AM
red_one Re: Minimum battery voltage February 12th, 2017, 11:32 AM
    Dec 2015
    What would be the minimum battery voltage needed to start the engine?
    I have a 02 Crosswind XTO
    Sent using Tapatalk
    9V. Pero hirap na sya. I replaced battery after.
    Sa 10V, its a few weeks left. Assuming usual first start... Not multiple straight starts
    Quote Originally Posted by istan View Post
    diba * 9v tulak na ito diba ^_^
    Nastart ko pa at 9V. Pero may dasal na kasama. Hahahaha!
    Quote Originally Posted by Janemar View Post
    Depende sa starter motor, cabling at compression ratio at number of cylinders...
    Pero usually 8.5v pataas kaya pa.
    i see, sakin pala naalala ko pag ON ko ng auto eh totally wala na umilaw sa dash. pero nakuha pa sa tulak ^_^
    May 2009
    pero sa naranasan ko minsan e 11.5 volts hindi na kaya...different car brand though. after chinarge ng 8 hrs ayun ok uli. sabagay beyond the service life na yung battery kaya pinalitan din few days after charging.
    Jul 2016
    Quote Originally Posted by XwindXTO View Post
    Sent using Tapatalk
    Aug 2012
    9V while cranking is okay. Normal na bumaba ang voltage during cranking.
    9V at rest (not cranking) is already dead battery. 10.5V is 0% charged.
    Sent from my D5833 using Tapatalk
    Sep 2013
    It's not voltage that determines whether you can start the car, but it's the starter's ability to deliver amperage. A volt meter will only give you a rough idea of the state of charge assuming that the battery is known to be in good condition. An average car batt produces roughly 400 to 500A to start the car. Assume the car batt is 9V while cracking but the ampere is only 70 so di pa rin mag-start ito
    Aug 2012
    Quote Originally Posted by kimbon View Post
    So how do you measure the remaining amperes of your battery? Para alam mo kung magstart pa engine?
