Page 50 of 479 FirstFirst ... 4046474849505152535460100150 ... LastLast
Results 491 to 500 of 4790
    Feb 2013
    #491
    Quote Originally Posted by 170kphlang View Post
    sana alisin na din nila yung clean blue at palitan ng bronze :D or yung talagang color blue na nakikita natin sa mga pics.
    actually that blue not the light blue in the promo pics was my first choice too bad walang dumating
    wafu!
    Feb 2013
    #492
    to those asking kung ok sa arangkada...yes hanep sa arangkada! akala mo maiiwan ka sa upuan
    don't forget that this has a 128 horsepower with 260 torque and VGT ( variable geometry turbo )...yes naka TURBO po! kaya dapat marunong gumamit ;)
    Does a turbo engine require a cool down period?
    Answer:
    Yes, a Turbo requires a cooling down time. How long a time really depends on how hard the car was driven prior to wanting to turn it off.
    A turbo requires oil to circulate through it in order to keep it cool and lubricated. When you turn your engine off, the Turbo will continue to spin only oil will stop being supplied to the turbo unless the engine is running. THis can cause th turbo to heat up, and for residual oil still on the turbine blades to "cake" on to them. Over time, unless you allow a col down period, you will notice a substancial difference in the performance of your turbo.
    Most car manufacturers will not even mention this to you when buying a car with a turbo, and if they do, they will generally recomend a cool down period of 10 seconds. I would suggest 30 seconds after regular driving, and 1 - 1 1/2 minutes after hard driving. from google
    Feb 2013
    #493
    Quote Originally Posted by njgarin View Post
    Correct me guys if im wrong. I think this is because of the different turbos used. Ford uses a traditional turbo charger that needs to spool up while Accent uses a VGT which allows you to get a certain turbo boost even on low revs. VGT doest spool up thus the term variable geometry allowing boosting in low aspect ratios. You will thus feel a better boost on Ford on as revs get higher while Accent starts its turbo boost even on low revs kaya di masyado ramdam pag mataas n rev mo kasi nung mababa palang may boost na.
    this is what i like about it kahit low rev gumagana na yung turbo!
    Mar 2011
    #494
    ayaw nyo nang red
    meron dito naka display malapit sa amin
    Hyundai sucat branch
    diko lang alam kung matic o manual
    1st display na white nawala na tapos ung silver nawala na rin
    tapos ngaun ung display red
    #495
    The ford focus is also common rail vgt
    Feb 2013
    #496
    Quote Originally Posted by b0y37 View Post
    but it's gas and 2.0 as compared to accents 1.4 and 1.6 diesel
    Jul 2011
    #497
    Quote Originally Posted by snoot View Post
    FYI, sir ang crdi ay para lang sa diesel engines.
    ang alam ko nga di na sila naglabas ng diesel variant sa bagong ford focus.
    Feb 2013
    #498
    Quote Originally Posted by s10pao View Post
    that's what i'm referring to the new focus since they don't have diesel variants, gas only. sorry for the confusion. i guess we are talking about new cars here not old ones.
    #499
    how does the quality of the ride compare to your civic and crv? mas matagtag ba ang accent?
    I agree with a previous post na maganda ang dark gray
    Mar 2012
    #500
    Answer:
    Sarap imaneho siguro niyan ah, ano ba pang mod sa naka turbo na VGT diesel para lalong lumakas sipa? hehe
    Question, ang cool down ba pang turbo lang? Kapag hindi nakaturbo na petrol hindi na ba need?
Hyundai ACCENT Hatch CRDI 1.6
