Page 665 of 808 FirstFirst ... 565615655661662663664665666667668669675715765 ... LastLast
Results 6,641 to 6,650 of 8072
    #6641
    Quote Originally Posted by Wh1stl3r2 View Post
    4 years of Euro 2 fuel and mostly city driving was really bad for the egr.
    kaya ako basta diesel ever since lumabas ang euro4 di na ako nagfi-fill up ng euro2. the worst of the big 3 is petron diesel (mausok) followed by shell (low power, mabilis maubos). pag walang-wala na talaga naghahanap ako ng caltex. even now that petron say they are euro4 medyo mausok pa din ang regular diesel nila. yung dieselMax ok lang kaso mahal naman.
    Oct 2015
    #6642
    I think uusok pa rin talaga at load bro. Sa Europe may nakita akong Euro 5 engines na mausok. Ang hirap linisin ng egr ng Euro 4 GS, masikip yung side na dinadaanan ng egr. I wonder how the early examples of GS with Euro 5 engines are doing. 2011 yung amin pero meron na rin lumabas Euro 5 the next year. Matagal tagal din nakagamit mga 2012 models with Euro 5 engines ng Euro 2 diesel.
    Apr 2012
    #6643
    Sorry I missed this thread. Suspension was finally fixed by Fronte. Turned out to be a couple of bushings and stab links. Fronte only does the work in their parking area but at least the mechanics know more about Hyundais in general.
    GS had low power going uphill so I had the egr cleaned yesterday. Sobrang barado na. Egr tube, valve and intake manifold were all gunked up. So was the cat converter. 4 years of Euro 2 fuel and mostly city driving was really bad for the egr. I didn't have it blanked as it still had Hancars "warranty". It now runs like new.
    Next up will be the intercooler.
    Marunong na sila maglinis ng Euro5? 2 years ago i brought mine sa Goodgear di nila kaya pa. Iba daw kasi engine
    Sent from my LG-H818 using Tapatalk
    Jun 2012
    #6644
    No need clean the egr pag euro 5 di ba? Dahil may dpf. Tama ba?
    Sent from my SM-G920F using Tapatalk
    #6645
    Quote Originally Posted by dct View Post
    afaik need pa din boss. hiwalay function nun. yung egr recirculates the exhaust back to the intake manifold to lower engine combustion temp which in turn lowers NOx production. yung dpf nasa exhaust pipe mismo, it catches the sulfur soot from the exhaust. nagre-regenerate siya, burning the soot by injecting diesel into the dpf. yung dpf is positioned after the egr inlet e.
    Oct 2015
    #6646
    Forgot to mention sa casa ginawa yung egr cleaning, went back to Hyundai Cainta. No choice, sila lang kasi malapit sa amin. They did mention the Euro 5 engines's egr layout was easier to clean. We did the catalytic converter and exhaust cleaning at home. Ganda ng takbo after.
    Kelangan pa din linisin sir if you haven't blanked it. Specially if it spent a lot of kms on Euro 2 fuel we had prior to this year. DPF simply catches all the soot so it doesn't go out the tail pipe. It is downstream of the egr. Will get back to you re: brake pads. I'm testing a new set right now. We also replaced the front rotors last week.
    Jun 2012
    #6647
    Kailangan na rin replace ng rotor? Madugo ata gastos sir ah. Ang dami
    Oct 2015
    #6648
    57 Tkms na din natakbo sir, also mahina talaga parts ng Hyundai compared to Japanese makes. We also had a Tucson before, replaced front and rear rotors at 45 Tkms. Pwede pa naman gamitin yung rotors pero lampas na sa recommended wear limit which is 2mm. Mahina na kumagat.
    Jun 2012
    #6649
    Ouch. Kailangan pala paghandaan
    #6650
    San ok magpatingin ng A/C ng GS? Nabilad kahapon, matagal lumamig.
    Sent from my Motorola Startac
2008 Hyundai Starex (Gen. 4)
