Page 765 of 808 FirstFirst ... 665715755761762763764765766767768769775 ... LastLast
Results 7,641 to 7,650 of 8072
    #7641
    Pag napalitan ko na sir will try to post pic. Ang hirap alisin yung bulb ng facelifted headlight. Meron cw arrow na may "LOCK" pero ayaw naman umikot ccw.
    Pin by Boyet Mejia on h1 bulb replacement | Pinterest
    Pati sa lumang headlights bro,- mahirap palitan ang H7 low beam bulb....
    I recently replaced my two low beam bulbs (Philips Xtreme Power pa),- napundi one after the other....
    Makapal kasi ang rubber seal...
    #7642
    Di ko pa din maalis yung bulb socket. Ibang-iba sa dating headlight na may latch at spring. Parang need ko alisin isang screw pero takot ako baka mahulog sa loob. Hanap pa ako ng magnetic tip na philips screw driver. So this project is postponed till january at byahe na ako bukas.
    Tagaytay kami kanina, pa bless ng gs sa pink sisters at punta sa little angels orphanage. Ok naman except sa as usual na overinflated tires. I checked both front and rear were at 51 psi! Lowered it to 42 psi front and 45 psi rear, ok na takbo afterwards di na maingay.
    Meeep! Meeep! Nakakahiya halos ayaw ko gamitin ang horn!
    #7643
    May nabili akong horns from korea na swak sa stock horn harness. Orig Mobis Snail Horns. 2-3 weeks dumating. Kating kati na kasi ako palitan si meep meep pero concerned sa warranty.
    #7644
    Eto pala yung horns.
    215-217 Sonata Plug and Play Dual Horn Kit - Shark Racing
    Dec 2018
    #7645
    Saan po nakaka bili ng cover ng nut sa wifer?
    #7646
    Quote Originally Posted by riga View Post
    For the first time, aligned the tyre pressure to the 42-47 mix... Maingay....😉😂😂
    #7647
    Bro, ang tanong nya e saan daw nakakabili ng kansursilyo (cover ng nut sa wifer!)
    #7648
    puyat yan si bro cvt, gimik kasi ng gimik ^_^
    #7649
    LSD ba ang Grand Starex? Managed to spin the rear wheels on a steep angled slope kanina. Sandali lang dumulas pero after a while kumapit naman...
    #7650
    Abs and esp lang yata. Kaya ba ng esp ang pigilan ang wheel spin para maging like-locking differential na din siya?
2008 Hyundai Starex (Gen. 4)
