Results 81 to 90 of 113
BANNED BANNED BANNED
- Jul 2010
- 106
July 2nd, 2010 10:44 PM #81Mga Hondas,what is the best gasoline sa honda civic vti 1997?Shell unleaded?Caltex Silver?petron unleaded?Yan lang mga kinakarga ko sa honda ko.Before when I still in province,Petron o shell lang.Pero nun nalaman ko na ang caltex silver daw ay maganda sa makina at matipid daw,caltex silver nako palagi.
- Jul 2010
- 106
July 3rd, 2010 02:43 PM #82Petron Blaze nalang yata walang E10 pero ang mahal.pero lalakas daw hatak sasakyan pag eto gamit.totoo?
- Apr 2010
- 18
August 17th, 2010 10:03 AM #83Does anybody have an idea if it's possible to convert a Fuel-Injected car which is not yet compatible to E10 fuel? I have a Honda City 1999 LXi (Not the Type Z model), and honda posted it that it's not yet compatible for E10. I have already loaded it up with XCS for a couple of months until I discovered honda's posting.
I'll be loading up with Blaze until there's a solution for conversion.
I'd like to know if you guys have an idea on how much it will cost if there's a conversion kit available.
Thanks!
August 17th, 2010 10:43 AM #84
I believe Petron's BLAZE also has blended enthanol.
Good thing that you have EFI . . . think of the other old cars that still has carburated engines. :twak: it is even much worse!
August 17th, 2010 12:38 PM #85
i have a 99 carb corolla that runs e10 blended petrol with no drama, apart from a corroded canister valve and somewhat bad fuel economy (1.3 engine gets only 7-8, wtf? minsan it's 6-7 pag barado na air filter).
my previous 96 and 99 civic a/t ran e10 just fine and dandy.
my 98 a32 even likes seaoil extreme e10.
so my opinion here is: if it ain't broke, don't fix it. run that baby on any petrol you like until the engine breaks. then replace the whole engine na lang (which, i think, is more cost effective than repairing the old one and converting it to run like a flex fuel vehicle) then run another 100,000 kms.
by then, wasak na yung kotse. time for a new one which ought to be compatible with e10 by then.
August 17th, 2010 02:24 PM #87
August 17th, 2010 02:27 PM #88
problems on EFI cars with E10 would include (but not limited to) the following:
-rust in the gas tank (from the water content in the e10 gasoline)
-hardening of the non-ethanol compatible rubber fuel hoses.
-erosion/corrosion of some metal fuel hoses (resulting in pin hole leaks).
- Dec 2006
- 234
August 17th, 2010 11:41 PM #89
- Apr 2010
- 18
August 17th, 2010 11:54 PM #90*ghosthunter
and also, what is the safest fuel to load for now? my first option, as what i've already stated on my first post, is Petron Blaze.
pag ethanol-blended lang yung fuel (not 10%-90% mixture), like XCS (if i'm not mistaken, is not E10 but still contains ethanol -- around 5%?), me negative effect pa din kaya sa kotse?
naninigurado lang.. i'm currenly draining the currently loaded XCS. just making sure na tama yung maikakarga ko after
thanks again.
Tesla Philippines
