Page 22 of 390 FirstFirst ... 121819202122232425263272122 ... LastLast
Results 211 to 220 of 3899
    Jun 2006
    #211
    Interesting thread. We use Donaldson and fleetguard filters on our CAT generator sets. Cheaper than CAT OEM filters.
    Did not know they can also be used for our rides. Anyone know the oil filter model number for Avanza 1.5?
    Dec 2007
    #212
    Quote Originally Posted by userfriendly View Post
    For Toyotas I like going slightly bigger these are just a 1 inches longer. Cross with a FRAM PH3614
    Fleetguard LF3335
    Largest OD 76.81 mm (3.024 in)
    Overall Height 88.65 mm (3.49 in)
    Thread Size 3/4-16 UNF-2B
    Baldwin BT223
    Thread: 3/4-16
    O.D.: 2 29/32 (73.8)
    Length: 3 1/2 (88.9)
    Donaldson 550335
    Thread Size: 3/4-16
    Length: 3.4" (86 mm)
    Outer Diameter: 3" (76 mm)
    STOCK Toyota
    Crosses as FRAM PH4967
    Fleetguard LF3614 is the cross but I would not use because it does not have a anti drain back valve or bypass valve.
    Baldwin b33
    Thread: 3/4-16
    O.D.: 2 11/16 (68.3)
    Length: 3 (76.2)
    Donaldson 502024
    Thread Size: 3/4-16
    Length: 2.56" (65 mm)
    Outer Diameter: 2.68" (68 mm)
    I would go with the bigger filter. And it will fit with no issues.
    These will fit basically all Toyota 4cly and 6cly vehicles except ones with 1kzte, TD42, Engines. 100% Will fit 1999 and UP 4cly and 6cly engines.
    Be sure to share where and how much you payed for yours.
    #213
    Quote Originally Posted by edtf View Post
    As stated in previous posts I have bought both na. Baldwin is sold by Volmax and I got my fleetguard from W&L
    I have used my Baldwin B2 for my Disco and I am currently using the fleetguard for my 4d56.
    Sir edtf, san ba yung location W&L na store na yan, or maybe even the contact nos.? Thanks
    Interested ako sa Fleetguard for my 4m40 and 4ja1 as I have ones experienced problems in the oil filter quality (blocked), good thing my engine didn't konk out so I'm in the hunt for a good oil filter...
    Dec 2007
    #214
    4M40
    Baldwin BD28
    Donaldon P551343
    Fleetguard LF3564
    4JA1
    Baldwin B1446
    Fleetguard LF3786
    Donaldson P502039
    http://www.wnltradingcorp.com/WLT/welcome.page
    W&L Trading Corporation
    #33, 8th street,
    New Manila
    1112 Quezon, Philippines
    Phone: +632 722-1880
    Fax: +632 721-9356
    Davao Branch
    Door 1 Lex Building, R.Castillo
    Agdao, Davao City
    Tel No(082)222-7839 • (082)222-7894
    Fax No: (082)222-7894
    Email: wnlcorporation*yahoo.com
    Cebu Branch
    Unit 2 & 3 VMS Building,
    UN Avenue Alang-alang,
    Mandaue City
    Tel No: (032)345-0503 • (032)345-0506
    Email: wnl_cebu*yahoo.com
    #215
    hehehehe nope baldwin only
    W&L sells the fleetguard and Donaldson
    If you are down south (of Manila lang) there is also one in Laguna techno Park psoted by dvldoc and another one in Las Pinas. Both are listed in the Yellow Pages.
    Thanks, I will try Fleetguard. Do they sell fuel filters for 4m40 as well? Or Baldwin lang yung may fuel filter?
    #216
    They Do.. Please check the following sites for the cross-reference.
    Just be careful with indirect crosses as size and thread size matters, always double check and compare the width, diameter, ADBV, PSI setting of bypass valve, oil seal diameter..
    The recommended
    Fleetguard:
    http://www.fleetguard.com/catalog/js...sreference=yes
    Baldwin:
    http://catalog.baldwinfilter.com/startproductguide.html
    Donaldson:
    https://dynamic.donaldson.com/webc/W...reference.html
    ChampionLabs/ Luberfiner:
    http://www.luberfiner.com/catalog/parts-catalog.aspx
    Wix:
    http://www.wixfilters.com/filterlookup/
    Others
    Mann + Hummel (Europe):
    http://www.mann-hummel.com/mf_prodka...=3&ktlg_lang=1
    Ryco (Australia):
    http://www.rycofilters.com.au/catalogue/xref
    Japanese:
    JS Asakashi:
    http://www.js-filter.com/catalogue
    Sakura:
    http://www.sakuracatalogue.com/filte...ra/filter2.php
    Vic:
    http://www.eiken-kk.com/vicf.html
    The not so recommended:
    Fram:
    http://www.framcatalog.com/Application.aspx?b=F
    Dec 2007
    #217
    This covers most old school turbo diesels and some of the new ones. Covers Air, fuel and oil filters. Enjoy
    http://www.odms.net.au/files/organis...%20NEW_V14.pdf
    http://www.fleetguard.com/pdfs/produ...s/3300964A.pdf
    http://www.acdelco.com.au/PDFs/Catal...s_20-05-10.pdf
    Note there are alternative filters you can run vs what is stated that fit and have the same or very close bypass valve pressure.
    #218
    I saw some fleetguard fuel filters. Not sure what sizes. Funny thing is I do need to buy a filter or two Volmax carries Baldwin fuel and air filters too
    #219
    great listing. I usually do a cross reference on their website but this is good. I shall print them out too.
    May 2004
    #220
    any model number for 1kzte(toyota) and 4jg2(isuzu) for fleetguard, baldwin etc? tia
Remote bypass oil filtration
