Results 1,271 to 1,280 of 3899
February 24th, 2012 09:45 PM #1271
February 24th, 2012 09:48 PM #1272
- Jun 2005
- 3,774
February 25th, 2012 09:08 AM #1273i use bt233 for the 2 vios with 1NZFE 2NZFE engines and corolla with 2e engine. fits well. no leaks.
i wouldnt worry about it hitting potholes. malayo pa yung oil filter. unang tatamaan yung oil pan. besides bt223 is only about an inch longer and the metal casing seems sturdy enough
February 25th, 2012 09:14 AM #1274
where did you bought that LF3564 blue_gambit?
i don't think fleetguard's are constructed that way...
February 25th, 2012 09:16 AM #1275
That's because that filter is a fake. I'm also sure it has no country of origin, was not wrapped in plastic and did not have the proper date code on the top of the filter.
February 25th, 2012 10:05 AM #1276
- Jun 2005
- 3,774
February 25th, 2012 10:27 AM #1277BT223 Costs P215 sa volmax. dont bother asking about the b33 wala sila stock nun. hehehe
its a perfect filter in terms of cost imho. a replacement vic costs 180. An original toyota cost 315 sa casa. a baldwin bt223, which is superior than any one of the 2 costs only 215. at 3k kms, my oil still looks fresh
im using regular toyota oil or idemitsu oil. mineral lang.
February 25th, 2012 10:35 AM #1278
February 25th, 2012 11:43 AM #1279
February 25th, 2012 11:54 AM #1280
dvldoc, how about this top1 diesel oil, can I use this in both 2nz-fe and 1tr-fe gasoline engines? this is the semi-synthetic diesel oil.
SAE Grade 15W-40 CI-4 <-------------------Not S rated
API Gravity 29.1
Viscosity
SUS * 100º F 503
SUS * 210º F 76
cSt * 40°C 116
cSt * 100°C 15.6
Viscosity Index 140 <------------- is this still too low?
Flash Point, C° (F°) 238 (460)
Pour Point, C° (F°) -39 (-38)
Total Base Number 11.8
Ash, Sulfated, wt% 1.37
Phosphorus, wt % 0.127
Zinc, wt % 0.137 <---------------- not sure if this is ok for cars with cat-con
Foam Test Pass
As for the filter, with the Vios, im just worried that if its too long, it might hit potholes, which might cause problems. as for the size, the important thing is that they have the same size(3/4-16UNF) right? . the Oring gasket size(54x62rnd) is not important?
Tesla Philippines
