Page 28 of 390 FirstFirst ... 182425262728293031323878128 ... LastLast
Results 271 to 280 of 3899
    #271
    Pics naman sir?
    Mali pala bro, the fuel filter that had a plunger on top was on the Dmax TDi. The Innova has a fuel separator as well.
    Apr 2011
    #272
    Quote Originally Posted by miked View Post
    Mabuksan nga sa weekend yung Vic na gamit na sa bahay. I'll check the internals kung ano klaseng material ang ginamit.
    sir, anu na un materials ng vic filters, is it cellulose or foam lamang po? pictures naman po dyan.
    Dec 2007
    #273
    VIC is Cellulose, They tend to dye there filter media for some reason could be a resign or something to strengthen it, I be curious to see some different ones cut open.
    #274
    A good add on to this thread if people can post the aftermarket filters they see on the shelf there so we can tell you which are the good and the not so good.
    So far we know this.
    Fleetguard - Fleet service heavy duty filter
    Baldwin- Fleet service heavy duty filter
    Bosch- good over the counter filter
    Mann- decent filter not the best specs for efficiency but well built
    Fram- Orange can of death, one of the worst on the market.
    OEM-Toyota black can not made by Mann, Low quality filter
    OEM-Honda low quality filter paper end caps, cheaply made
    OEM-Madaz decent filter good for 5000k oil changes
    OEM-Nissan white can, total garbage, foam filter media thin cardboard
    Nissan- made by Mann, decent over the counter filter 5000k use.
    Mobil1-good over the counter filter
    K&N - good over the counter filter
    WIX- above average oil filter heavy duty construction.
    OEM-Ford (Motorcraft filter) Good over the counter filter
    ACDelco-None Ultraguard and Duraguard are of very low quality
    OEM-Hyundai-good OEM filter
    VIC- Very cheaply made, restrictive bypass valve, poor filter media
    Union-Decent over the counter filter, basic paper media 5000k Change out
    JHF- Decent Koren made over the counter filter 5000k use
    Fil- lable says (for) Toyota, red and white box, Yellow lettering on filer, undersized filter media, bad bypass valve cause filter to recirculate unfilterd oil.
    Fil-Fram Koren version. same issues. Steel on steel relief valve fails to seal, leaves dirty oil circulating.
    Toyota (Denso) Japan, has on average fewer pleats for fitering vs other filters. Example MANN has 60 pleats vs Densos 29, vs Frams 59 in the same size filter. Very short life filter.
    Fellow Tskoit member await your input
    Purolator makes good oil filters as well right? It's the one my friend bought kasi. Can't find W&L Trading kasi and Volmax in Manila.
    Jul 2010
    #275
    Never pa kaming nakaexperience na me magreklamong customer na sumabog ang Fleetguard filters.
    FYI lang mga bros.
    Dec 2007
    #276
    Purolators are perfectly good filters, I have posted plenty of pics of them on the site.
    The Purolator Premium line of oil filters are 96% efficient * 30 microns; 85% efficient * 20 microns and 60% efficient * 10 micron. There Purolator classic is 97.5% at 35 microns.
    So they filter about as well as a standard Fleetguard but not as heavy duty construction. But for a daily driver they are perfect. But nothing wrong with a purolator they are solid filters. I do believe Speedlab carries these as there standard filter.
    #277
    Thanks, this is the onesI have bought and it will arrive soon. Will change my filter once it arrives. P560 for it. Hope to see significant reduction in oil particles flowing in the engine. Ace hardware.
    #278
    wow. Purolator is expensive din pala. i was expecting high 300s lang yung price.
    Bosch filter. 390 bili ko sa distro nila.
    #279
    San yung Distro CB ?
    #280
    warren auto supply BG, sa binondo ito.
    390 for 4M40 and 350 for 4D56 yata.
    WARREN AUTOMOTIVE CO
    Business Type: Motor Vehicles and Parts
    1054 BENAVIDEZ ST, BGY 294, ZONE 028 BINONDO
    Manila, Metro Manila
    244-1775
Remote bypass oil filtration
