Results 2,481 to 2,490 of 3899
July 24th, 2012 06:57 AM #2481
The ones here are made in Malaysia, i took a look at some already, they are not the same as the US made ones. The other big give away is the plasticc on the bottom of the filter. 5he construction see far. Lighter than the ones from the states. If my tools wlere not all (borrowed) by my in-laws i would cut one open.
July 24th, 2012 09:52 AM #2482
My remote bypass set up installed on my Elgrand.
The black filter is my Luberfiner XL series which is 98.9% efficient at 20 microns and 50% * 5 microns and is a full flow and a full synthetic wire backed synthetic media.
http://www.luberfiner.com/documents/...single-pgs.pdf
And the second is my Fleetguard Venturi combo filter. Basically the best spin on filter you can get for the money period. 98.9% efficient at 20 microns on the full flow and 98.9% efficient at 5 microns on the bypass section.
http://www.cumminsfiltration.com/pdf...LT36043-GB.pdf
http://www.cumminsfiltration.com/pdf...es/LT36043.pdf
I will safely be able to go around 35000klm between oil changes. I'm using Mobil Delvac 1300 super 15w40 with a bottle of zddp plus to get my zinc phosphorus levels to around 1800ppm. Engine is extreamly smooth and the oil only has a light black tint to it. The first 2 days it was still clear.
I will do a oil analysis at 10000k on the oil. Getting a sample is easy I just open up the port on the side of the filter mount.
July 24th, 2012 02:46 PM #2483
July 24th, 2012 02:50 PM #2484
July 24th, 2012 07:43 PM #2485
35000klm for these filters is under utilizing them. But i figure with the baf fuel here i did not want to push it to far, of course that depends on the oil test resuults.
- May 2012
- 85
July 25th, 2012 11:40 AM #2486Guys just a question regarding Montero oil filters. I called the CASA, they said for the 4d56, the 1230A045 is the OEM filter. for the 4M41, it's the 1230A046. Question is, can i use the baldwin/Fleetguard filters that crosses to the 1230A046?
Will the diameter/length fit? I looked at the oil filter position of the 4d56, it looks like a tight fit.
July 25th, 2012 11:43 AM #2487
- May 2012
- 85
July 25th, 2012 12:01 PM #2488
July 25th, 2012 12:14 PM #2489
July 25th, 2012 12:41 PM #2490
Tesla Philippines
