Results 1,261 to 1,270 of 3899
February 24th, 2012 02:31 PM #1261
Yes Luberfiner is a quality filter, I use them as well. I'm using there imperial XL series as part of my dual bypass system they are 5 micron filters, I replaced my other side with the LF9028 fleetguard Venturi bypass filter which is about as good as it gets.
Luberfiner are for fleet service just like Baldwin and Fleetguard, they are not over the counter filters you can get in a autoparts store.
The black ones are my Luberfiners
Here's a 4M40 filter from Luberfiner.
February 24th, 2012 02:55 PM #1262
dvldoc, how about this top1 diesel oil, can I use this in both 2nz-fe and 1tr-fe gasoline engines? this is the semi-synthetic diesel oil.
SAE Grade 15W-40 CI-4 <-------------------Not S rated
API Gravity 29.1
Viscosity
SUS * 100º F 503
SUS * 210º F 76
cSt * 40°C 116
cSt * 100°C 15.6
Viscosity Index 140 <------------- is this still too low?
Flash Point, C° (F°) 238 (460)
Pour Point, C° (F°) -39 (-38)
Total Base Number 11.8
Ash, Sulfated, wt% 1.37
Phosphorus, wt % 0.127
Zinc, wt % 0.137 <---------------- not sure if this is ok for cars with cat-con
Foam Test Pass
As for the filter, with the Vios, im just worried that if its too long, it might hit potholes, which might cause problems. as for the size, the important thing is that they have the same size(3/4-16UNF) right? . the Oring gasket size(54x62rnd) is not important?Last edited by crazy_boy; February 24th, 2012 at 02:59 PM.
February 24th, 2012 04:23 PM #1263
Hi dvldoc just wanna ask if this is the real deal LF3564, if its not is this still worth using? especially compared to a VIC-313 filter for my 4M40... Thanks
I guess this is what you meant with the combo filter... hehehe
Tsikot Member Rank 1
- Jul 2009
- 4,090
February 24th, 2012 05:43 PM #1264
February 24th, 2012 05:54 PM #1265
Ayus lang paps malay mo orig ung lf3564 eh di un na muna gamitin ko... Kung fake man tong fleet guard ko mukhang maganda ung construction and material nya. Hehehe... Sayang din, muntik ko na makalimutan. Hehehe
- Jul 2009
- 4,090
February 24th, 2012 06:31 PM #1266
February 24th, 2012 06:41 PM #1268
- Jul 2009
- 4,090
February 24th, 2012 07:18 PM #1269
February 24th, 2012 08:01 PM #1270
Doc, are fleetguard and baldwin's recommended to be extended up to 8k to 10k of use on truck engines?
Tesla Philippines
