Results 211 to 220 of 3899
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 6th, 2011 08:00 PM #211Interesting thread. We use Donaldson and fleetguard filters on our CAT generator sets. Cheaper than CAT OEM filters.
Did not know they can also be used for our rides. Anyone know the oil filter model number for Avanza 1.5?
May 6th, 2011 08:31 PM #212
For Toyotas I like going slightly bigger these are just a 1 inches longer. Cross with a FRAM PH3614
Fleetguard LF3335
Largest OD 76.81 mm (3.024 in)
Overall Height 88.65 mm (3.49 in)
Thread Size 3/4-16 UNF-2B
Baldwin BT223
Thread: 3/4-16
O.D.: 2 29/32 (73.8)
Length: 3 1/2 (88.9)
Donaldson 550335
Thread Size: 3/4-16
Length: 3.4" (86 mm)
Outer Diameter: 3" (76 mm)
STOCK Toyota
Crosses as FRAM PH4967
Fleetguard LF3614 is the cross but I would not use because it does not have a anti drain back valve or bypass valve.
Baldwin b33
Thread: 3/4-16
O.D.: 2 11/16 (68.3)
Length: 3 (76.2)
Donaldson 502024
Thread Size: 3/4-16
Length: 2.56" (65 mm)
Outer Diameter: 2.68" (68 mm)
I would go with the bigger filter. And it will fit with no issues.
These will fit basically all Toyota 4cly and 6cly vehicles except ones with 1kzte, TD42, Engines. 100% Will fit 1999 and UP 4cly and 6cly engines.
Be sure to share where and how much you payed for yours.
May 7th, 2011 04:59 AM #213
Sir edtf, san ba yung location W&L na store na yan, or maybe even the contact nos.? Thanks
Interested ako sa Fleetguard for my 4m40 and 4ja1 as I have ones experienced problems in the oil filter quality (blocked), good thing my engine didn't konk out so I'm in the hunt for a good oil filter...
May 7th, 2011 05:12 AM #214
4M40
Baldwin BD28
Donaldon P551343
Fleetguard LF3564
4JA1
Baldwin B1446
Fleetguard LF3786
Donaldson P502039
http://www.wnltradingcorp.com/WLT/welcome.page
W&L Trading Corporation
#33, 8th street,
New Manila
1112 Quezon, Philippines
Phone: +632 722-1880
Fax: +632 721-9356
Davao Branch
Door 1 Lex Building, R.Castillo
Agdao, Davao City
Tel No(082)222-7839 • (082)222-7894
Fax No: (082)222-7894
Email: wnlcorporation*yahoo.com
Cebu Branch
Unit 2 & 3 VMS Building,
UN Avenue Alang-alang,
Mandaue City
Tel No: (032)345-0503 • (032)345-0506
Email: wnl_cebu*yahoo.comLast edited by dvldoc; May 7th, 2011 at 05:30 AM.
- Nov 2009
- 3,503
May 7th, 2011 11:12 AM #216They Do.. Please check the following sites for the cross-reference.
Just be careful with indirect crosses as size and thread size matters, always double check and compare the width, diameter, ADBV, PSI setting of bypass valve, oil seal diameter..
The recommended
Fleetguard:
http://www.fleetguard.com/catalog/js...sreference=yes
Baldwin:
http://catalog.baldwinfilter.com/startproductguide.html
Donaldson:
https://dynamic.donaldson.com/webc/W...reference.html
ChampionLabs/ Luberfiner:
http://www.luberfiner.com/catalog/parts-catalog.aspx
Wix:
http://www.wixfilters.com/filterlookup/
Others
Mann + Hummel (Europe):
http://www.mann-hummel.com/mf_prodka...=3&ktlg_lang=1
Ryco (Australia):
http://www.rycofilters.com.au/catalogue/xref
Japanese:
JS Asakashi:
http://www.js-filter.com/catalogue
Sakura:
http://www.sakuracatalogue.com/filte...ra/filter2.php
Vic:
http://www.eiken-kk.com/vicf.html
The not so recommended:
Fram:
http://www.framcatalog.com/Application.aspx?b=F
May 7th, 2011 11:30 AM #217
This covers most old school turbo diesels and some of the new ones. Covers Air, fuel and oil filters. Enjoy
http://www.odms.net.au/files/organis...%20NEW_V14.pdf
http://www.fleetguard.com/pdfs/produ...s/3300964A.pdf
http://www.acdelco.com.au/PDFs/Catal...s_20-05-10.pdf
Note there are alternative filters you can run vs what is stated that fit and have the same or very close bypass valve pressure.Last edited by dvldoc; May 7th, 2011 at 11:56 AM.
- Jan 2007
- 409
May 7th, 2011 02:44 PM #218
- Jan 2007
- 409
May 7th, 2011 02:47 PM #219
May 7th, 2011 02:52 PM #220
any model number for 1kzte(toyota) and 4jg2(isuzu) for fleetguard, baldwin etc? tia
