Page 300 of 656 FirstFirst ... 200250290296297298299300301302303304310350400 ... LastLast
Results 2,991 to 3,000 of 6552
    Aug 2014
    #2991
    Ako gamit ko delo 400, pero kahit lagpas 6 mos ok pa yan, di na tulad dati mga dino oil, sa bitog forum nga dino oil + dual bypass filter kaytagal nila gamitin
    walang problema, delo 400 may moly content na maganda naman both protection ang lubrication yung delo gold wala.
    Jan 2011
    #2992
    Meron po ba bad feedback dito sa Motul na fully synthetic yung TRD na 5w-40, yun kase gamit kong oil?
    Quote Originally Posted by marion2 View Post
    For gasoline engine or the turbo diesel version?
    Mar 2005
    #2994
    Na test ko na yung Motul TRD 5W40 na pang diesel sa Santa Fe and Montero for 10k OCI. Wala naman difference ako napansin vs sa Specific CRDI at sa Kixx Turbo RV. AFAIK mas mataas TBN ng Specific CRDI vs TRD. Na curious lang ako kaya na try ko kung may difference ba sa mas murana Kixx. Sa next oil change ko back to Kixx ako.
    Sep 2009
    #2995
    I think the 1.2 TBN difference dow not make any difference and the added value is negligible because our diesel sulfur limit is now low. BTQ, Sulfur turns to SO2 inside the ICE, which turns to sulfuric acid because of the combustion water byproduct.
    Aug 2012
    #2996
    Quote Originally Posted by andrewnathaniel View Post
    Salamat mga bro sa replies. Hindi naman stop and go yung route namin. Ang problem lang kasi eh bihira lang talaga magamit. Pwede ba kahit per year na lang ang oil change kung Delo 400 kung hindi man maka-5,000 kms? Hindi ba sya agad madedegrade? TIA
    If you have the vehicle owner's manual, just follow the factory recommended oil change and filter change intervals. Be sure to use the correct oil grade for your engine.
    If you don't have the vehicle owner's manual, here is a general recommendation:
    #2997
    Ikaw na kasi sumubok, maganda naman specs eh and knowing how good japanese products are, hindi ka naman magkakaproblem dyan for sure.
    oo nga eh hehe
    iyon nga lang nauwi din ako sa zic a+
    #2998
    Salamat sa mga replies bro. Nakita ko sa net yung Shell Rimula R4 pala eh API CJ-4 na. Php 200+ lang tanong ko sa gas station per liter. May nakasubok na ba nito? Mineral lang ba to o semi-syn na?
    Shell Rimula R4 L - Philippines
    #2999
    Which is better as per data sheet? Hindi ko alam alin titingnan eh.
    Shell Rimula R4 vs Delo 400
    http://www.epc.shell.com/docs/GPCDOC...GE)_TDS_v1.pdf
    https://cglapps.chevron.com/msdspds/...&docFormat=PDF
    #3000
    Good luck makakita ka Rimula R4 L. Afaik Shell Rimula R4 lang meron sa mga Shell stations. CI-4 yun.
    And to answer your second question, much better yung Delo 400.
Mineral , semi synthetic or fully synthetic?
