Page 237 of 656 FirstFirst ... 137187227233234235236237238239240241247287337 ... LastLast
Results 2,361 to 2,370 of 6552
    Nov 2013
    #2361
    Mga boss, may alam ba kaung autoshop na ngbebenta ng Zic oil sa bandang Cavite/Las Pinas? Thanks.
    Mar 2005
    #2362
    Quote Originally Posted by johnjoseph View Post
    Suking auto supply ko, along Quirino hiway, Sangandaan, QC, near SM Hyprmrt. Mali pala compute ko, Php190/ltr pala, mahina talaga ako sa spelling. :-)
    Posted via Tsikot Mobile App
    Uy malapit lang samin yan ah. Yan ba yung sa may tapat ng Hypermart na halos tabi ng Cowboy Grille? Ano pa mga Zic oils nila dyan sir?
    Due na for change oil yung Rav4 ko na less than 5,000kms a year lang tinatakbo so need ko ng cheap lang na oil pero ok pa din performance.
    Jul 2012
    #2363
    For those using Fully synthetic oils that follows every 10k km interval, what brand of oil filters you usually use alongside the fully synth oils that can also last the 10k duration?
    Mar 2005
    #2364
    Quote Originally Posted by leodawesome View Post
    Gamit ko sir Royal Purple Oil Filters sa Jazz, Sonata at Rav4 for 10,000kms or 1 year. Good feedback din yung Baldwin Filters.
    #2365
    Where do you get your RP filters?
    Sent from my Nexus 7 using Tapatalk 2
    Jul 2012
    #2366
    I'm actually using royal purple oils. I'm not aware na meron din sila filters. Can you share boss kung saan ka nakakakuha?
    I'm currently using Purolator oil filters with the royal purple oils by the way. Try ko magexperiment ng iba.
    Apr 2010
    #2367
    help lang: I'm planning to have a change oil sa aming 323, sa shell. OK ba yung oils ng shell and how much?
    planning din na mag change oil sa Automatic tranny ng kotse namin as well. magkano kaya siya?
    or any other recommended na auto shop na OK magpa-change-
    oil?
    Mar 2005
    #2368
    Order ko online then balikbayan box. Got a good deal ng mga RP filters 2 years ago kaya nag stock na lang ako for personal use.
    Jul 2012
    #2369
    Ah I see, so wala pala locally. Baka meron ka jan spare boss that you might wanna sell
    Mar 2005
    #2370
    Sabihan kita sir I might order RP Filter for my Hyundai Santa Fe as soon as mahanap ko na yung tamang fit. So far ang stock ko lang ay pang rav4 Part# 10-267, Jazz 10-2840 and Sonata 10-28-76.
    Anyone tried Mag 1 FMX oils? Any feedback?
    Inspection Data
    Specific Gravity * 60°F (15.6°C) ASTM D4052 0.8522
    Viscosity * 40°C cSt ASTM D445 63.95
    Viscosity * 100°C cSt ASTM D445 10.93
    Viscosity Index ASTM D2270 163
    Pour Point °C (°F) ASTM D5950 -45°C (-49°F)
    Color ASTM D 1500 2.5
    Cold Cranking Simulator at (°C), cP ASTM D5293 4800 (-30)
    High Temperature / High Shear Vis at 100°C, cP ASTM D 6616 7.15
    High Temperature / High Shear Vis at 150°C, cP ASTM D5481 3.2
    Noack Volatility, % loss ASTM D 6375 10.5
    Calcium, wt. % ASTM D 5185 0.169
    Zinc, wt. % ASTM D 5185 0.091
    Phosphorus, wt. % ASTM D 5185 0.079
    Sulfur, wt. % ASTM D 4951 0.252
    Boron, wt. % ASTM D 5185 0.023
    Molybdenum, wt. % ASTM D 5185 0.0079
    Sulfated Ash, wt. % ASTM D 874 0.92
    Nitrogen, wt. % ASTM D 4629 0.102
    Pumping Viscosity at (°C), cP ASTM D4684 18,400 (-35)
    Shear Stability ASTM D 6278 9.43
    Foam Seq. I (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    Foam Seq. II (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    Foam Seq. III (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    High Temperature Foaming, static foam ASTM D 6082 (Opt A) 0/0
    Gravity, °API ASTM D287 34.54
    Copper Strip Corrosion (3 hrs*100°C) ASTM D 130 1a
    TBN, mgKOH/g ASTM D 2896 7.9
    Product Details - Mag 1
    429 pesos kuha ko sa Landmark Trinoma Hardware Store with 10% discount pa dahil sale kanina. Bali 386 na lang per quart. Gamitin ko sana to sa Gasoline Fortuner sa next oil change.
Mineral , semi synthetic or fully synthetic?
