Results 2,361 to 2,370 of 6552
- Nov 2013
- 8
April 14th, 2014 10:28 PM #2361Mga boss, may alam ba kaung autoshop na ngbebenta ng Zic oil sa bandang Cavite/Las Pinas? Thanks.
April 14th, 2014 11:04 PM #2362
Uy malapit lang samin yan ah. Yan ba yung sa may tapat ng Hypermart na halos tabi ng Cowboy Grille? Ano pa mga Zic oils nila dyan sir?
Due na for change oil yung Rav4 ko na less than 5,000kms a year lang tinatakbo so need ko ng cheap lang na oil pero ok pa din performance.
April 14th, 2014 11:09 PM #2363
For those using Fully synthetic oils that follows every 10k km interval, what brand of oil filters you usually use alongside the fully synth oils that can also last the 10k duration?
April 14th, 2014 11:14 PM #2364
April 14th, 2014 11:17 PM #2365
Where do you get your RP filters?
Sent from my Nexus 7 using Tapatalk 2
April 14th, 2014 11:20 PM #2366
I'm actually using royal purple oils. I'm not aware na meron din sila filters. Can you share boss kung saan ka nakakakuha?
I'm currently using Purolator oil filters with the royal purple oils by the way. Try ko magexperiment ng iba.
April 15th, 2014 03:18 AM #2367
help lang: I'm planning to have a change oil sa aming 323, sa shell. OK ba yung oils ng shell and how much?
planning din na mag change oil sa Automatic tranny ng kotse namin as well. magkano kaya siya?
or any other recommended na auto shop na OK magpa-change-
oil?
April 15th, 2014 03:23 AM #2368
April 15th, 2014 05:23 PM #2369
Ah I see, so wala pala locally. Baka meron ka jan spare boss that you might wanna sell
April 15th, 2014 10:33 PM #2370
Sabihan kita sir I might order RP Filter for my Hyundai Santa Fe as soon as mahanap ko na yung tamang fit. So far ang stock ko lang ay pang rav4 Part# 10-267, Jazz 10-2840 and Sonata 10-28-76.
Anyone tried Mag 1 FMX oils? Any feedback?
Inspection Data
Specific Gravity * 60°F (15.6°C) ASTM D4052 0.8522
Viscosity * 40°C cSt ASTM D445 63.95
Viscosity * 100°C cSt ASTM D445 10.93
Viscosity Index ASTM D2270 163
Pour Point °C (°F) ASTM D5950 -45°C (-49°F)
Color ASTM D 1500 2.5
Cold Cranking Simulator at (°C), cP ASTM D5293 4800 (-30)
High Temperature / High Shear Vis at 100°C, cP ASTM D 6616 7.15
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 3.2
Noack Volatility, % loss ASTM D 6375 10.5
Calcium, wt. % ASTM D 5185 0.169
Zinc, wt. % ASTM D 5185 0.091
Phosphorus, wt. % ASTM D 5185 0.079
Sulfur, wt. % ASTM D 4951 0.252
Boron, wt. % ASTM D 5185 0.023
Molybdenum, wt. % ASTM D 5185 0.0079
Sulfated Ash, wt. % ASTM D 874 0.92
Nitrogen, wt. % ASTM D 4629 0.102
Pumping Viscosity at (°C), cP ASTM D4684 18,400 (-35)
Shear Stability ASTM D 6278 9.43
Foam Seq. I (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
Foam Seq. II (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
Foam Seq. III (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
High Temperature Foaming, static foam ASTM D 6082 (Opt A) 0/0
Gravity, °API ASTM D287 34.54
Copper Strip Corrosion (3 hrs*100°C) ASTM D 130 1a
TBN, mgKOH/g ASTM D 2896 7.9
429 pesos kuha ko sa Landmark Trinoma Hardware Store with 10% discount pa dahil sale kanina. Bali 386 na lang per quart. Gamitin ko sana to sa Gasoline Fortuner sa next oil change.
Tesla Philippines
