Results 51 to 60 of 6552
June 25th, 2011 07:51 PM #51
June 25th, 2011 08:03 PM #52
IMO kung top-up lang walang masamang mangyayari long-term. Pero next time, yung same brand na lang sana rin if wala na choice. Kasi liek sa shell helix, yung added components lang sa base yung nagpapamahal sa tsikot eh, so more or less compatible pa yan.
Next oil change naman mapapalitan na majotiry eh.Not much worry IMO.
Fasten your seatbelt! Or else...Driven To Thrill!
- Aug 2010
- 278
July 28th, 2011 11:00 AM #53do turbo diesel need fully synthetic oil, or can i use mineral
wala kasi ako mabasa sa booklet ng 4m41 na "use fully synthetic oil only" and nag tanong ako sa mitsubishi marcos na ang nirerecomend daw nila eh fully synthetic dahil daw turbo diesel ang makina ko
July 28th, 2011 12:30 PM #54
July 28th, 2011 01:02 PM #55
Basta multigrade na pasado sa API rating na kelangan puwede na. But for new engines, use semi or fully synthetic depending upon your service intervals. You can compute naman whichever will give the best benefit and not much cost.
for example, twice a year ka lang magpapalit since hindi malalayo biyahe mo, better to use semi or fully syn para ok pa oil mo kahit matagal na sa engine. Kung every 3 months ka magpapalit, multigrade or semi-syn is best.Fasten your seatbelt! Or else...Driven To Thrill!
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 28th, 2011 01:47 PM #56mineral or synthetic, parehas pwede naman basta you follow the correct drain interval
April 26th, 2012 11:39 AM #57
April 26th, 2012 12:45 PM #58
buy the best oil with the best specifications( additive package/base oil)...
pag mineral kaya mostly 5000kms ang recommended change oil because it degrades very easily when used...
if you use semi synthetic you can extend it a little further provided you use a good filter...(not VIC)
if you use fully synthetic you can DEFINITELY extend your intervals...and extend it FURTHER with a good filter again...(not VIC)
the TRUE advantage of fully synthetics over semi and mineral oils is not the interval it can give but the edge in terms of
*shear protection (oil film strength)
*soot dispersion (can hold more particles in suspension)
*fuel economy (high viscosity, superb cold start protection)
*and resistance to oil oxidation due to the fact that they are synthetics (degradation)
- Nov 2003
- 3,848
April 26th, 2012 02:59 PM #59mineral oil is fine if you're very religious with your intervals. if you'd like a bit more leeway with it then better to use full syn oil.
April 26th, 2012 03:04 PM #60
Ako I'm not sold on semi synt, either mag mineral ka or fully synth...
Tesla Philippines
