Results 21 to 26 of 26
- 53,883
October 29th, 2019 11:38 AM #21i would replace my belt, when it shows minute cracks on the ridged inner surface. kuripot ako.
others would replace theirs, after every xxxx km, regardless of belt condition. pms to the fullest definition! heh heh.
- Jul 2014
- 31
October 29th, 2019 12:25 PM #22Thank you guys for the inputs. Papasadahan ko nalang for the next PMS if due for replacement na talaga. More power tsikot!!
September 18th, 2024 02:35 PM #23
Napansin ko yung drive belt Altis ko parang may tahi sa outer part. Tapos ngaun parang lumalalim na yung tahi. is that a sign to replace?
- Jan 2007
- 2,452
September 18th, 2024 11:09 PM #24From the 4runner forums: Replacement OEM Serpentine Belt fraying?! | Toyota 4Runner Forum
I contacted Bando for a definitive answer. They’re the ones producing these made in the USA OEM belts for Toyota.
Here’s the engineer’s response:
“That fraying will eventually wear off. The fabric is only stitched to hold it in place during the building of the belt. The rubber impregnated fabric is cured to the backing of the belt so the stitching isn’t relevant to the functioning of the belt during use.
Most auto manufacturer’s have transitioned to a rubber backed belt without any fabric backing. As I mentioned on the phone, our aftermarket belts do not have the fabric backing.”
I bought a second belt from Toyota and it’s obvious the same stitching will have similar results. Glad there’s nothing to worry about.
Hopefully this might help someone else.
- 53,883
September 19th, 2024 12:14 AM #25i pay attention to the cracks that might appear on the inside, perpendicular to the long axis.
the other week, i had the altis belt replaced.
it didn't have many cracks, but it had been making squeaking noise when started from cold in the morning.
i googled and saw the squirt-water test.
ok na si new belt. tahimik na ulit.
September 23rd, 2024 06:40 AM #26
One of the indicators of a premature worn serpentine belt is the sign of the pulley groove crest that is polished and the groove valley of the belt being in contact with the pulley crest. The belt was designed to have contact with the inclined surfaces of the belt and the pulley. Also check for debris stuck in the pulley grooves.
Tesla Philippines
