Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Jul 2014
    Guys, normal po ba yon parang my basa don sa belt? Click image for larger version.
    Nope.
    Jan 2009
    Is it actually wet, or is the surface has just become shiny and polished due to wear?
    Quote Originally Posted by bokswager View Post
    that's not wet. that's shiney dry.
    turn off the engine, and put your finger to it, and be convinced.
    the belt surface gets shiney because with use, the surface is polished shiney.
    it seems, somewhere in its roundabout trip, that side passes over a very fine or shiney metal surface.
    normal.
    Apr 2014
    Sa nakikita ko parang un polished side ng isang pulley either ng water pump, idler, or tensioner. At un belt is sa ilalim nya nadaan (sorry hinde talaga clear).
    Pwede nyo po check sa owners manual para makita yun route ng belt. So pag belt mismo yun nasa visible side ng picture at ang nakikita is yun ribbed side ng belt sa part na yan at makinis at makintab na sya is baka waiting for replacement na.
    If yun non-ribbed side nya ang supposedly na makikita sa side na yan, then pwede nyo po check as mentioned na pasadahan ng daliri para malaman kung basa. Pero kung makintab is normal lang lalo na sa serpentine belts.
    Jul 2014
    normal.
    Copy sir, hindi ko pa nitry hawakan, usually nag inspect the car after drive home from work, usually inaangat ko ang bonnet pra mabilis magpalamig ng engine. So noticed that shiney thing don sa belt nya.
    Ilan kms na? Papalitan mo na. Wala mura lang naman yan saka mabilis lang papalitan.
    about lifting the bonnet to cool down the engine faster...
    i don't.
    unless we are going to tinker with the engine, which is usually nicer if it were cooler ...why want to make engine cool down faster?
    it's an engine.
    it's not a living thing.
    "we are bestowing characteristics of living things, to an inanimate object."
    Jul 2014
    72k na natakbo sir. Yon bang belt nya sa baba yan ba yun serpentine belt?
    Jul 2014
    i don't.
    it's an engine.
    Agreed with you, atleast from time to time nakikita ko lang loob ng engine bay at naoobserve ko whats happening under the hood.
Drive belt engine
