Page 89 of 235 FirstFirst ... 397985868788899091929399139189 ... LastLast
Results 881 to 890 of 2348
    Sep 2006
    #881
    Quote Originally Posted by jsaure72 View Post
    Ok naman yung switch, could having my injection pump checked help solve this?
    Check the downshift cable. It may be out of adjustment.
    You can also try the "transmissions" forum at Tsikot. You my get better inputs.
    May 2009
    #882
    Sir DieselDude at fellow tsikoteers,
    Ako naman ngayon ang nagkaproblema. My engine is 4D56T..kahapon lang e nagfflicker ung oil pressure light. kapag nirebolusyon e nawawala at kapag hindi inapakan ang accel pedal e nago-"on" ung warning light ng oil pressure. nangyari na ito dati last june 2009 i think but due to low oil levels.
    Pero ngayon iba naman. ok naman ang oil level. i'm using delo gold 15W-30.
    Last oct 2009 eto mga pinagawa ko:
    1. change cyl head gasket
    2. change valve seal
    3. cyl head grinding
    4. change oil and filter
    Eto naman ang mga iniisip ko na checkpoints:
    1. sending unit baka defective
    2. due to oil leaks sa oil cooler lines (bka humihigop hangin kasi matagal ko nang hindi napagawa ung kaunting leaks)
    3. worn engine bearings (crank and cam)
    4. plugged oil filter? ewan ko lang kasi may bypass naman.
    5. plugged oil filter? ewan ko rin.
    Sa mga nakaexperience nito kindly share naman. it would be a great help at least i have some ideas bago ko ipaconfine ang pipip ko. thanks a lot mga sir!
    Sep 2006
    #883
    Try using 15W-40. Mainit na ang panahon ngayon.
    Temporarily remove sending unit, and put in a mechanical pressure guage to see the true oil pressure. If pressure is OK, replace the sending unit.
    2. due to oil leaks sa oil cooler lines (bka humihigop hangin kasi matagal ko nang hindi napagawa ung kaunting leaks) Hindi pwede humigop ng hangin sa oil cooler dahil pressurized ito.
    3. worn engine bearings (crank and cam) Possible cause ito ng low oil pressure. To confirm, you have to check the condition of the crank bearings, and measure bearing to crankshaft oil clearances.
    5. plugged oil filter? ewan ko rin. Hindi siguro pwede ito dahil nabanggit mo na kapapalit mo lang ng oil filter.
    May 2009
    #884
    Salamat sir dieseldude sa reply esp. sa #2 item. nga pala i forgot that i was using delo gold monograde sae 40 pala. last year pa yung 15w-30. my problem is finding a mechanic with complete tools esp ung mechanical oil pressure gage. i'm praying na hindi pa sana pudpod ang mga main bearings. ...
    #885
    sir diesel dude, I just bought a 95' mitsu pajero JDM(surplus) with a 4m40 2.8li engine, A/T tranny, and 4wd. I really dont have any problems with my rig. Yung fuel consumption lang, I only get 6km/li on city driving. Is that normal? or do I need to have it calibrated?
    exhaust is ok, no black or gray or white smoke. Tires are all stock
    Sep 2006
    #886
    6km/L * city is quite high. Check your air intake system, etc.
    City driving cannot be an accurate indication of fuel consumption due to many variables. Try hi-way driving.
    Feb 2010
    #887
    DieselDude,
    Hey got my bighorn fixed, yep had the cable fixed too and now it runs fine. Thank bro
    #888
    If I decide to have it recalibrated, how much will it cost me kaya? thanks
    Quote Originally Posted by Dieseldude View Post
    Sep 2006
    #889
    DieselDude,
    I'm glad. You're welcome.
    Oct 2009
    #890
    sir: need your opinion... may problema ang vacuum system ng 97 hlander ko... noticed na mataas ang idling... had it checked by a mechanic... ang sabi: wala daw suction yun hose connected sa alternator... baka daw barado... ok pa naman ang electrical system ko... di ko alam na may connection sa alternator ang vacuum system ng engine ko... sorry, newbie sa diesel engine kasi...na rerepair pa ba ito? thank you very much!!
Diesel Fuel Injection System Help Desk
