Page 8 of 119 FirstFirst ... 4567891011121858108 ... LastLast
Results 71 to 80 of 1184
    Dec 2009
    #71
    Guys mas ok ba baldwin fuel filter kesa sa oem mitsubishi fuel filter? Thanks
    Posted via Tsikot Mobile App
    #72
    Quote Originally Posted by radz15 View Post
    Yes, mas mataas filtration capability nung baldwin.
    Apr 2014
    #73
    Quote Originally Posted by AC View Post
    Attachment 22046
    kita ko lang sa facebook.. parang maganda din..
    ito yung gamit ko ngayon sa montero, vic c-306. vic f-193 naman sa fuel filter.
    Apr 2012
    #74
    Quote Originally Posted by miggymontero View Post
    magkano presyo ng vic filters sir miggy? feedback mo later sir ilang kms inabot bago ka magpalit..TIA
    Apr 2014
    #75
    Nabili ko siya sir ng 380 pesos, each. Kakapalit ko pa lang sir. At 17669km ako nagpalit, around 200km pa lang ang na takbo. Sige sir mag update ako dito.
    Jul 2015
    #76
    Best are fram ultra, fleetguard, baldwin, donaldson
    Worst are vic, sakura
    Jun 2005
    #77
    Quote Originally Posted by amoyligo View Post
    sa remote bypass thread, di daw maganda ang fram
    Jul 2015
    #78
    Quote Originally Posted by sirkosero View Post
    Yung mga dating fram yun.
    Pero fram ultra maganda.
    Aug 2015
    #79
    [QUOTE=Ry_Tower;1766120]
    Originally Posted by dvldoc
    A good add on to this thread if people can post the aftermarket filters they see on the shelf there so we can tell you which are the good and the not so good.
    So far we know this.
    Fleetguard - Fleet service heavy duty filter
    Baldwin- Fleet service heavy duty filter
    Bosch- good over the counter filter
    Mann- decent filter not the best specs for efficiency but well built
    Fram- Orange can of death, one of the worst on the market.
    OEM-Toyota black can not made by Mann, Low quality filter
    OEM-Honda low quality filter paper end caps, cheaply made
    OEM-Madaz decent filter good for 5000k oil changes
    OEM-Nissan white can, total garbage, foam filter media thin cardboard
    Nissan- made by Mann, decent over the counter filter 5000k use.
    Mobil1-good over the counter filter
    K&N - good over the counter filter
    WIX- above average oil filter heavy duty construction.
    OEM-Ford (Motorcraft filter) Good over the counter filter
    ACDelco-None Ultraguard and Duraguard are of very low quality
    OEM-Hyundai-good OEM filter
    VIC- Very cheaply made, restrictive bypass valve, poor filter media
    Union-Decent over the counter filter, basic paper media 5000k Change out
    JHF- Decent Koren made over the counter filter 5000k use
    Fil- lable says (for) Toyota, red and white box, Yellow lettering on filer, undersized filter media, bad bypass valve cause filter to recirculate unfilterd oil.
    Fil-Fram Koren version. same issues. Steel on steel relief valve fails to seal, leaves dirty oil circulating.
    Toyota (Denso) Japan, has on average fewer pleats for fitering vs other filters. Example MANN has 60 pleats vs Densos 29, vs Frams 59 in the same size filter. Very short life filter.
    Fellow Tsikot member await your input [quote/]
    Purolator makes good oil filters as well!
    Read more: http://tsikot.com/forums/engine-fuel...#ixzz1Or1EcsGl
    mga sir sa intindi ko po dito mas maganda ang union kaysa vic? union kasi nagamit kong oil filter, union at vic lang kasi nasa shell nung nagpachange oil ako. thanks
    Apr 2012
    #80
    May Bosch kaya na fuel filter for Hiace Commuter? 2015 model
Best Oil/Fuel Filters
