Page 213 of 227 FirstFirst ... 113163203209210211212213214215216217223 ... LastLast
Results 2,121 to 2,130 of 2269
    #2121
    Hindi pa yan plugged sa outlet when I took the picture.
    ilan hours na patay engine bro?
    mas ok kasi if CCA rating makita, pero if 12 hours na patay engine and ganyan ang reading ibig sabihin nag retain parin ng charge.
    btw ganyan new charger ko pero 6A version, lintek sa kupad mag charge hahaha
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    #2122
    Hahaha wala ako alam sa ganyan.
    BTW 4 days ng patay ang engine [emoji23]
    #2123
    Here’s mine, checked it kanina.
    how long have you had it?
    does it work, i.e., de-sulphate sulphated batteries?
    Jan 2009
    #2124
    We have four of these, two mobile and two semi-permanently mounted.
    #2125
    ah 12.7v eh good yun batt mo bro
    #2126
    Sulit. Mag 3 years na din.
    #2127
    Napapaisip tuloy ako if I should replace the battery of my 11th gen na. It 5 1/2 years already but I am curious if it will beat my 10th gen's record. Ang issue ko lang, sa 10th gen ko, saan man ako abutan pwede ako pa push start kasi manual, e yung 11th gen ko a/t
    Jan 2008
    #2128
    suggestion lang po.. replace the capacitors inside with a good / durable brand.. yung sa tropa ko pumutok agad yung caps.. replaced with a good one.. ok na
    #2129
    I believe na if it ain’t broke why fix it?
    Mura lang naman ito, first time to buy a car battery charger. If ever masira will consider buying yung pricey na mas matibay tibay na.
    Still thank you sa suggestion [emoji16]
    #2130
    did the friend mention how much it cost him to replace them caps?
    and yes,
    some caps do last long.
    it's a gamble, what the buyer gets in his purchase.
Amaron battery
